MSI B550M Mortar firmware for EC chip 25X20CL
  • flusher
    • Oct 2015
    • 47
    • Ukraine
    Hello, so I have this motherboard that was power cycled during bios update and it never boots up. I tried flashing bios from USB stick. Process completes but does not help. I also tried desoldering bios chip and programming it with CH341 to first and latest versions. No joy. So the board is just stuck on CPU led and does not move any further, i checked that we have vcore, vcc on bios chip and rest important voltages, however I noticed that it does not power off when holding power button for 4 sec. So it leads me to believe something is wrong with EC which is Nuvoton NCT6687D-R. It actually has a small flash chip nearby so I was thinking maybe it is worth a try. However I don't have same board to read it, also I tried unpacking bios dump and looking for suitable size for this flash (the same theory as with asus tpu/rog binaries inside) but could not find anything that match.
    Does anyone has same board lying around to read the dump or help unpacking its contents from bios flash?
    Any help is appreciated. Thanks.
    Attaching some photos for clarity.
  • flusher
    • Oct 2015
    • 47
    • Ukraine
    Re: MSI B550M Mortar firmware for EC chip 25X20CL
    anyone?
    • peste
      • Dec 2016
      • 12973
      • ROMANIA
      Originally posted by flusher
      anyone?
      post the original bios even if it is corrupted...
      • flusher
        • Oct 2015
        • 47
        • Ukraine
        the problem is not in the bios chip but in eeprom near the nuvoton EC, should i upload my original eeprom?
          • 21200
          yes post it.
          • flusher
            • Oct 2015
            • 47
            • Ukraine
            here it is
            • flusher
              • Oct 2015
              • 47
              • Ukraine
              bought same board and confirmed contents of the EC eeproms are the same. later having other board I was able to find an issue in one of the power rails of the "PCH" chip, fixing that actually solved the problem. board works fine.
              someone may find above dump useful, it works 100%
              admin may you please close this topic.
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • DynaxSC
                ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                by DynaxSC
                Hi
                I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                08-04-2025, 12:20 PM
              • stormy1777
                Pantum CM1100adw firmware w/no chip
                by stormy1777
                Hi friends.
                Got the CM1100adw color printer and delighted at the prospect of being able to break-free from this "chip" on inks/toners!!!
                Read many posts on topic.. wondering if someone can help:
                HTML Code:
                Firmware Version: 3.E.1.2
                Engine Version: 1.0.6.8
                HTML Code:
                Q044RlYwMDA3Rzo6MzExMjAwMEY6OkFDOkM1OjFCOjUxOkJCOjVFOjozLkUuMS4yJFNJRzQwMDhmYzZmYjgxNDU1MWMwZTJiMTkxZjM1ODkyNGUzOjpCdWlsZHRpbWU6IFRodSAxOSBTZX
                AgMjAyNCAxMToyOToxMCBBTSBDU1Q6OjEwMjQ6OkNNMTEwMEFEVwA6OjEuMC42LjgAOjo1Ljg6Og==
                Assuming i'd want to do myself, is it possible to read/dump...
                06-27-2025, 09:13 AM
              • BMCappelletti
                Asus Chromebox CN62 - wrong chip put on BIOS reader
                by BMCappelletti
                Long story short:
                - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                - gave the computer to his son a couple years later
                - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                (seems like the story was not that short)
                He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                01-08-2025, 07:27 PM
              • chaos_prevails
                Dell Latitude E7470 i7: no TPM + TXT in BIOS/Firmware (but chip is present on the motherboard)
                by chaos_prevails
                I've purchased 2nd hand Dell Latitude E7470 i7-6600U and it works fine, except ... there are no TPM or TXT/Trusted Execution settings in the BIOS/Firmware. However, looking at the schematics I found the chip handling TPM (NPCT650JA0YX) soldered to the system board. Also, looking at the service tag and the product specifications, this device comes with TPM (and vPro) support (I know that devices sold in China, Russia are not allowed to ship with TPM but this should be reflected in the service tag). I can also login to MBex to configure, etc.
                In the produce specs...
                02-12-2024, 05:21 AM
