GV-N1050OC-2GD bios
  • jabam
    • Sep 2020
    • 10
    • Philippines
    GV-N1050OC-2GD bios
    Hello friend.. do you have bios bin file for this gpu? GV-N1050OC-2GD the bios rom on techpower is too small than my backup bios..my old bios is 512kb but in techpower it is 253kb only..when i flash it via programmer, notification pop-up "data file is small than size of chips"
    please help me with tested bin file. thankyou
    • 21874
    Re: GV-N1050OC-2GD bios
    post the techpowerup bios
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • Forest79
      by Forest79
      07-23-2023, 07:39 AM
    • maanee11
      Help to get Lenovo BIOS bin file for Thinkpad T560
      by maanee11
      Hello Everyone,
      I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
      https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
      In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
      05-15-2022, 11:59 AM
