Anyone help me, looking for bios for 694d pro
  • catalina
    • Nov 2005
    I bought my 694d pro two years ago with 2 p3 733 from ebay. Now I want to update bios of the board, but I can not find the match bios file. the bios file I can get are for AI,AIR or AR, but i can not find the promise ata100 chip,iee1394 and raid on my board, so i think my board is msd 694d pro. without A,R,I.
    If anyone have the correct bios file, please kindly send it to my mail box , liluzhang@gmail.com
    thank you very much.
    ps: some of the caps near cpu are swallow or lead, i will visit badcaps.net and recap it.
    Mis 694d pro, 2 * p3 733, 2*512M NEC ECC SD
    Quadro nvs 280, Eizo T965, Seagate Cheetah 36XL
  • AK0R
    • Mar 2005
    • 204
    Re: Anyone help me, looking for bios for 694d pro
    From MSI's website, the latest BIOS file for the 694D Pro (without A, I, R) is v1.9; the file is 6321v19.exe. The file has been sent to your e-mail address. You can find it at http://www.msicomputer.com/support/bios_result.asp, then selecting 694D Pro (MS-6321) in the Model field and clicking Search.
    • catalina
      • Nov 2005
      thanks a lot.
      • AK0R
        • Mar 2005
        • 204
        The message was rejected by your server twice, once when I sent it as an .exe file, and again as a .zip file. You'll have to download it yourself.
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
        • maanee11
          Help to get Lenovo BIOS bin file for Thinkpad T560
          by maanee11
          Hello Everyone,
          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
          05-15-2022, 11:59 AM
