MSI Z270-A Pro (MS-7A71 Ver 1.2) Schematic Request
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1828
    • Spain
    Hi guys
    Does anyone have a schematic or board view for MS-7A71?
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • Rezistor
    • Jun 2021
    • 404
    • USSR
    • Exchange rare schematics of desktop motherboards, laptops, and video cards for personal use
    Re: MSI Z270-A Pro (MS-7A71 Ver 1.2) Schematic Request
    Originally posted by dicky96
    Hi guys
    Rich
    MS-7A71 Rev 1.2 schematic and boardview
    • re-atari
      • Oct 2010
      • 143
      Hi guys
      Rich
      Hi Richard,
      I watched your YT video in which you tried to fix this mainboard (I've been a subscriber to your channel almost since the very start).
      You could have saved yourself the trouble of desoldering the BIOS chip (twice), if you had used the JSPI1 socket to reprogram the BIOS chip. The sole purpose of this socket is (re)programming the BIOS, the pins are directly wired to the BIOS chip. It is more or less a more reliable version of a programming clip. I presume MSI uses this socket during production to program the BIOS. Detailed info about this socket is a bit hard to find, looks a bit like MSI views this as some sort of trade secret. So in that respect, it does makes sense you desoldered the BIOS chip in order to reprogram it.
      About a programming clip: it can indeed be a bit unreliable. Although (in my experience) a lot of the horror stories using a clip are somewhat exaggerated. I have used both a 8-pin and a 16 pin clip numerous times successfully for reading and writing BIOS chips. Using a good quality clip and connecting it properly to the BIOS chip should give correct reads/writes.
      Several years ago I fixed a MSI MS-7693 mainboard (ATI 970 chipset), that like your mainboard had a corrupt BIOS as well. I successfully reprogrammed it through the JSPI1 socket. The socket pins have 0.2mm spacing instead of the more common 0.254mm spacing. I used 2 wires with 5 leads each, to connect the JSPI1 socket to an 8-pin adapter that fits in a eprom programmer ZIF socket. I had the 2 wires in my surplus box, I think they were originally intended for connecting the audio out of a CD-Rom player to a mainboard or soundcard. Not sure, long time ago...
      I did have to connect an ATX PSU to the mainboard, as the programmer could not deliver enough juice to supply power to all IC's on the mainboard. Using my TL866, I got an 'overload' error. With the ATX PSU connected, all IC's on the mainboard got enough power, and the error disappeared. IIRC I did not connect a wire between the VCC on the programmer ZIF socket and the JSPI1 socket. I cannot remember if I had to switch the PSU on, or if I could just leave it on standby.
      I should have a description of the JSPI1 socket pin layout from back then stored on my laptop somewhere, but will have to search for it. I'm sure the schematics/boardview provided above will suffice to figure out how the socket and BIOS chip are wired up as well. The schematic should give you validation about the value of the missing resistor, which you mentioned in the update video about this mainboard's fix, as well.
      As for the cause of a BIOS going corrupt on MSI mainboards, I suspect it has to do with the 'live update' feature their mainboards boast. This feature enables a BIOS update on a system that has fully started up Windows or what have you, and that is just asking for trouble/failures. IMHO a BIOS update should only be done on a system just running the BIOS setup.
      So, in this case the saying 'it's not a bug, it's a feature' is not valid, rather quite the opposite, really.
      re-atari
      • andalusi
        • Apr 2014
        • 19
        • ALGERIA
        Thank you. I Have a short circuit in ATX power on my board
        • urribarrizr
          • Aug 2023
          • venezuela
          Muchas gracias Rezistor!
          Thank you very much Rezistor!
          in English please
          • Bifus_77
            • May 2026
            • 8
            • France
            Hi Richard,
            re-atari
            This is really interesting. Im researching about using the jig port in my asus g513rm instead of dismantling and clipping the programmer to the chip directly but Im having trouble finding clear instructions. I added by mistake a PK and now I need to clear the key from the PSP and write the bios back.
            Using the jig connector would make things so much easier.
              SMDFlea commented
              Editing a comment
              your motherboard does not have an SPI programming header. If the chip type on your board is WSON use a WSON pogo adapter.
          • Bifus_77
            • May 2026
            • 8
            • France
            I thought that this meant my MB had a JSP1 header (photo below).
            The chip is a SOIC-8, so was initially planning on using the SOIC pin connected to the SPI programmer but found this JSP header whilst reading the service manual of the G513RM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • Trademark
              Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
              by Trademark
              I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
              This is NOT a BIOS password removal request.
              I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
              Laptop Information
              • Model: Acer Predator Triton 16 PT16-51-99GL
              • Motherboard: DA0ZQDMB8AE Rev. E
              • Main SPI flash: Winbond W25Q256JVEN (32MB)
              • Secondary
              07-22-2026, 08:57 AM
            • Arzigol
              Acer Nitro Lite 16 NL16-71G (V1.19) - BIOS Unlock / Advanced Menu / CFG Lock
              by Arzigol
              Hello everyone!
              I am looking for experienced BIOS modders who can help analyze or unlock the BIOS of my Acer Nitro Lite 16 NL16-71G.
              Please note that this post was written with the help of ChatGPT because my English is limited. My native language is Russian. If anything is unclear, please let me know and I will do my best to explain.
              Laptop Information
              Model:
              Motherboard:
              CTE_NB_NL160P1G_RTH (NB6807C)
              CPU:
              Intel...
              07-12-2026, 02:27 AM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
            • Deniz
              IdeaPad Gaming 3 16IAH7 BIOS Issue / GPU Not Detected
              by Deniz
              Bu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
              I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
              I had the BIOS cleaned, but the issue was not resolved and there was still no image.
              Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
              After that, I tried to update the...
              01-27-2026, 06:56 AM
