HP ProOne 600 G1 AIO DMI copy
  • zolie
    • Jun 2015
    • 52
    • Hungary
    Hi, Can I ask for some help. The PC starts, there is no display, the led is red. I updated it from HP's site, but it doesn't have DMI and now it doesn't have data and the network doesn't work. How can I copy the old DMI data? Thanks!
  • hardware1
    • Sep 2021
    • 2943
    • N/A
    Re: HP ProOne 600 G1 AIO DMI copy
    Here's your New BIOS, it should works fine.
    Serial Number: CZC41061F1.
    all donations are welcome,
    • zolie
      • Jun 2015
      • 52
      • Hungary
      It's not working. I attached the working (HP's site) without DMI.
      • hardware1
        • Sep 2021
        • 2943
        • N/A
        Try this.
        • zolie
          • Jun 2015
          • 52
          • Hungary
          Try this.
          It's not working. More detailed:
          HP-ProOne-600G1-AIO_old.rar
          switch on, no pic, red light
          HP ProOne 600 G1 AIO (L01) (V_2.71).rar
          switch on, no pic, white led, fan spins up loudly
          L01_0221.rar
          switch on, working, no dmi, no eth
          L01_0221 (DMI+GBE).rar
          • hardware1
            • Sep 2021
            • 2943
            • N/A
            L01_0221.rar
            So if you try the file in Post #3 "L01_0221.rar" again , the device will works but with DMI an LAN Problem?
            I attached a file that could help you with LAN Problem, if it works fine you can use a (BCU tool) for your DMI.
            • zolie
              • Jun 2015
              • 52
              • Hungary
              Yes, the device works but with DMI and LAN Problem. All data is missing, name sn, mac address etc. MAC address was FF:FF:FF:FF:FF:FF:FF:FF.
              I'm gone for a few days now, but I'll check on Monday. By the way, how can I get this data out of the old bios? I tried with hxd, but I can't found it.
              • hardware1
                • Sep 2021
                • 2943
                • N/A
                You should to search for it in "Unicode". Go to that Offset (583105h) and you will see your DMI.
                • zolie
                  • Jun 2015
                  • 52
                  • Hungary
                  Now it is working. Thanks for your work!
                  • hardware1
                    • Sep 2021
                    • 2943
                    • N/A
                    You're Welcome, which one worked fine?
                    • zolie
                      • Jun 2015
                      • 52
                      • Hungary
                      L01_0221 (Just GBE).rar + BCU
                      In the meantime, I checked the 'bin' and realized that I couldn't find the DMI data because there is a dot between each letter...
                      • hardware1
                        • Sep 2021
                        • 2943
                        • N/A
                        Yes, as I told you in Post #8, you should search using "Unicode".
                        • zolie
                          • Jun 2015
                          • 52
                          • Hungary
                          Yes, I did it. Later But at the beginning I didn't know that. It was in the default setting and I couldn't find it.
                          • m0seba
                            how to block copy from network access
                            by m0seba
                            hi
                            there is a small company have 4 computers and server with windows server 2016
                            all computers are entered into the server by local users, and there is shared folders on server with limited access to every computer
                            my question is there any method to disable copping form all shared folders on this server, but jest disable copy form server not paste on it.
                            my client want his team copy from their computers and paste on any shared folders on server, on the other way can not copy anything from shared folders to their computer.
                            or any way to disable copy on windows...
                            03-16-2021, 03:35 PM
                            Copy DMI info easily with Hex editing software and Macro script
                            by SMDFlea
                            Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                            Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                            02-28-2023, 02:14 PM
                          • howardc64
                            Samsung UN55JU650DF network/streaming problem
                            by howardc64
                            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                            07-09-2025, 12:44 PM
                          • chaos-theory
                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                            by chaos-theory
                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                            03-14-2025, 05:37 PM
                          • davg
                            Home network connection problem
                            by davg
                            I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                            03-06-2021, 07:13 AM
