Lenovo Thinkstation P720 Bios
  • Zibbo
    • Mar 2017
    • 204
    • Zimbabwe
    I am kindly requesting Lenovo Thinkstation P720 Bios or if someone can fix my dump. S/N: S4JU3418
  • hardware1
    • Sep 2021
    • 2948
    • N/A
    Re: Lenovo Thinkstation P720 Bios
    Here's your New Bios, try it and give me the results.
    all donations are welcome,
    • Zibbo
      • Mar 2017
      • 204
      • Zimbabwe
      Working, thank you!
      • hardware1
        • Sep 2021
        • 2948
        • N/A
        Working, thank you!
        Good to know, You're Welcome.
        • Nicolae2023
          • Aug 2023
          • England
          Hello , it’s possible to have the bios dump file for Lenovo Thinkstation P720 s/n : S4NS3632 ? Kind regards
          • hardware1
            • Sep 2021
            • 2948
            • N/A
            Originally posted by Nicolae2023
            Hello , it's possible to have the bios dump file for Lenovo Thinkstation P720 s/n : S4NS3632 ? Kind regards
            You can try the working BIOS from Post #2, but you need to take a backup from your BIOS before flash this one.
            • Nicolae2023
              • Aug 2023
              • England
              I will try . Thanks
              • Deltatronic
                • Jan 2024
                • Poland
                Good morning everyone. This is my first post on this forum, so please be understanding.
                I received a board with a Lenovo P720 that does not boot. The fans work properly, but it does not turn on the USB ports and does not display the image.
                The motherboard is marked ASM(01LM602) and the computer is Lenovo ThinkStation P720 type 30BB.
                At first I thought it was the BIOS (MX25L25673G) but I uploaded a different one - the one from above and no changes.
                I suspect it is KBC Memory (NUVOTON NCT6685D). This is a separate WINBOND 25X40CL memory chip.
                However, I cannot find the contents of this memory anywhere.
                Does anyone know where I could find this or share it with me?
                Thank you very much for all your help and best regards​
                • kravma
                  • Apr 2021
                  • Ukraine
                  Originally posted by Deltatronic
                  Всем доброе утро. Это мой первый пост на этом форуме, поэтому прошу отнестись с пониманием.
                  Получил плату с Lenovo P720, которая не загружается. Вентиляторы работают исправно, но порты USB не включаются и изображение не отображается.
                  Материнская плата имеет маркировку ASM(01LM602), а компьютер — Lenovo ThinkStation P720 типа 30BB.
                  Я сначала подумал, что это биос (MX25L25673G), но залил другой - тот, что сверху и никаких изменений.
                  Я подозреваю, что это память KBC (NUVOTON NCT6685D). Это отдельная микросхема памяти WINBOND 25X40CL.
                  Однако я нигде не могу найти содержимое этой памяти.
                  Кто-нибудь знает, где я могу найти это или поделиться этим со мной?
                  Большое спасибо за вашу помощь и наилучшие пожелания
                  Здравствуйте! Попробуйте этот дамп, я его скачал со своей рабочей станции, но у меня типа 30ВА
                  Translated to english
                  Hello! Try this dump, I downloaded it from my workstation, but I have a 30VA type​
                  • scarso
                    • Jun 2024
                    • 7
                    • Italy
                    Hi, I have a problem with the bios of a lenovo Thinkstation p720 (model 30bb) with two xeon processors. During a bios update via windows routine there was a power failure and the computer has not booted since. I unsoldered the chip with the original bios and saved it to a file. I'm not bios expert and I don't know what can be done. I had hoped to find a compatible copy of bios on the Lenovo site but I saw that there was a They're just updates, not the whole original BIOS. The procedures suggested by the Lenovo site with emergency boot from cd or usb key and iso image, cmos battery removal etc do not work. The machine is quiet and only occasionally starts and produces three short and one long sounds. On the manual this corresponds to the absence of RAM memory (actually present with 6 banks), or to motherboards to be changed. Does anyone have a good bios that I could rewrite on the chip to try again? Thank you. (Translated online).
                      • 21861
                      If you post your corrupt bios backup and the PC serial number someone will help.
                      • scarso
                        • Jun 2024
                        • 7
                        • Italy
                        Right! Thanks for the suggestion, I'm new to this forum, I hope I can attach a 32 Mb file. The serial number is: S4KP8150.
                        Thank you in advance to those who will be able to help me
                          • 21861
                          Try this one. If it boots up ok,go to the support site https://pcsupport.lenovo.com/us/en/p...3-B07A93E0428C
                          ,download the windows bios update, run the exe and follow the instructions. Add the serial number,model type
                          * 2. Flash Under Operating System *
                          * 1. Please make note of any settings you have changed in the BIOS *
                          * Setup utility. They may have to be re-entered after updating *
                          * the BIOS. *
                          * 2. Go to the directory where the above files were extracted. *
                          * The default path is "cd C:\SWTOOLS\FLASH\xxxJYnnUSA", where "nn" *
                          * represents the two digit flash level. *
                          * 3. Double click the wFlashGUIx64.exe to start the flashing process. *
                          * 4. You would see a graphic tool popup,please check the message *
                          * carefulluy,then please click "Next" to continue. *
                          * 5. Then you will see the message "Would you like to update the Serial *
                          * Number?". If needed, please click "Yes" and input the Serial Nuber.*
                          * 6. Then you will see the message "Would you like to update the *
                          * Machine Type and Model?". If needed, please click "Yes" and input *
                          * the Machine Type and Model. then please click "Next" to continue. *
                          * 7. Then you may see the message to requie input BIOS administrator *
                          * password if it was set. Please input the correct password, *
                          * then please click "Next" to start the update process. *
                          * 8. The update may take up some time. Do not power off or restart *
                          * the system during this procedure! After the Windows update *
                          * process ends, the system will automatically reboot to finish *
                          * the flash process. *
                          * 9. The BIOS update process ends with above 8 steps. *
                          * Notes: *
                          * - You may see a POST error "0162: Setup data integrity check *
                          * failure" after step 9.Press F1 to enter BIOS Setup Utility, *
                          * and then press F10 to save your settings *
                          • scarso
                            • Jun 2024
                            • 7
                            • Italy
                            Thank you very much SMDFlea! I'll give it a try soon
                            • scarso
                              • Jun 2024
                              • 7
                              • Italy
                              Hi SMDFlea and thank you again for your interest.
                              ​It took me a while to unsolder and re-solder the chip... Now the computer started up for the first time with a beep as a signal, then turned off. Then it restarted and gave me a sound of 6 short beeps followed by two longer ones. Continuously until I turn off the machine at the button. Nothing appears on the screen. On the lenovo p720 manual, this beep sequence is not mentioned.
                              • scarso
                                • Jun 2024
                                • 7
                                • Italy
                                I just turned it back on and unfortunately it doesn't make any more sound and turns off on its own.
                                  SMDFlea commented
                                  Editing a comment
                                  Ok,will post another later,busy right now.
                              • scarso
                                • Jun 2024
                                • 7
                                • Italy
                                That would be a great help to me, thank you
                                • scarso
                                  • Jun 2024
                                  • 7
                                  • Italy
                                  If you need it, I'll attach this new sound in mp3 format (inside zip file)
                                  • ava123
                                    • Aug 2023
                                    • 23
                                    • Romania
                                    Hello!
                                    I have a lenovo thinkstation P720 , SN: MJ06VB9S.
                                    I tried the bios SMDFlea posted but i have the POST error "0162: Setup data integrity check ".
                                    Can you repair my bios dump?
                                    Thanks!
                                      • 21861
                                      Originally posted by ava123
                                      Hello!
                                      Thanks!
                                      It`s a common problem, do a google search for "0162: Setup data integrity check"
                                      • HammyCheesy
                                        Lenovo ThinkStation P720 BIOS Request
                                        by HammyCheesy
                                        Hello all,
                                        I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
                                        When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
                                        Type: 30BB
                                        Model Number: S03600
                                        S/N: MJ07N68C
                                        Things I have tried:
                                        1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
                                        2. Attempted to boot with just a single CPU...
                                        04-11-2025, 01:02 AM
                                        LENOVO ThinkStation P720 ThinkStation P 4114 Specification for Upgrade or Repair
                                        This specification for the LENOVO ThinkStation P720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation P720 boardview and ThinkStation P720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-12-2024, 02:15 PM
                                      • lucaszmn
                                        by lucaszmn
                                        Problem:
                                        Initial Findings:
                                        • I concluded that the
                                        08-12-2025, 03:01 PM
                                        LENOVO ThinkStation ThinkStation D20 (415522G), UK ThinkStation D E5520 Specification for Upgrade or Repair
                                        This specification for the LENOVO ThinkStation ThinkStation D20 (415522G), UK can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation ThinkStation D20 (415522G), UK boardview and ThinkStation ThinkStation D20 (415522G), UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                        09-12-2024, 03:36 PM
                                        LENOVO ThinkStation ThinkStation S20 (410528G), UK ThinkStation S E5502 Specification for Upgrade or Repair
                                        This specification for the LENOVO ThinkStation ThinkStation S20 (410528G), UK can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation ThinkStation S20 (410528G), UK boardview and ThinkStation ThinkStation S20 (410528G), UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
