Need Boardview/Schematics for 820-00609-A (iMac 27" 2017)
  • overshoot
    • Aug 2015
    • 9
    • thailand
    Do someone have those to share please?
  • Rezistor
    • Jun 2021
    • 302
    • USSR
    Re: Need Boardview/Schematics for 820-00609-A (iMac 27" 2017)
    Schematic
    • overshoot
      • Aug 2015
      • 9
      • thailand
      Originally posted by Rezistor
      Schematic
      Thanks buddy!
      • wolf88
        • Feb 2020
        • peru
        Hello colleagues, can someone share the BRD and pdf of 820-00609-A imac of 27 5k
        • SirDoad
          • Dec 2021
          Hello! Thanks for the schematics for this board. Could really use a BRD file though. I have a 2017 that has 3 Led lit and no chime so a BRD file could really. help me out! Thanks
          • joen_d66
            • Apr 2013
            • 68
            • jakarta
            Schematic
            thanks to sharing 🙏🏻
            • CG_Dionysos
              MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
              by CG_Dionysos
              I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
              • Model: A1707
              • 15-inch, Mid 2017
              • 3.1 GHz Core i7
              • 16 GB RAM
              • Radeon Pro 560
              • 1 TB SSD
              • Board number: 820-00928-A
              I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
              Thanks in advance!
              Greetings from Germany...
              09-16-2025, 06:43 AM
            • Tribalus43
              Lenovo Thinkpad T14 gen 2 intel schematics/boardview
              by Tribalus43
              Request: Lenovo ThinkPad T14 Gen 2 (Intel) Schematics/Boardview
              I’m looking for the schematics or boardview for a Lenovo ThinkPad T14 Gen 2 (Intel) with the following board:
              HT4B07HP4B0 / HT5B1 / HP5B1 / HT4B2 NM-D352 Rev: 2.0
              I’m currently dealing with some startup issues and would like to test for shorts. Any help would be greatly appreciated.
              Thanks!
              09-01-2025, 12:10 PM
            • Jag013
              HP OMEN 15-ax204ns Boardview and schematics
              by Jag013
              Hi, I need the boardview and schematicsfor an HP OMEN 15-ax204ns laptop, purchased in 2018, with the following specifications:
              • Processor: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
              • RAM: 4.00 + 4.00 GB
              • Hard Drive: 1TB
              • Product ID: 00325-96088-89605-AAOEM
              • N/S: 5CD70805T8
              I’m trying to repair a short circuit in the battery charging section.
              If you can help me locate the boardview and schematics or a boardview file, I would really appreciate it.
              Thank you for your help!...
              07-02-2025, 02:15 AM
            • tommy97
              iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
              by tommy97
              we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
              Any ideas what might've...
              04-20-2024, 04:48 AM
            • Daniel Kubica
              Lenovo Thinkpad T14 Gen 1 NM-C801 Schematics and Boardview
              by Daniel Kubica
              Hi, I needed a schematic and boardview for this motherboard earlier and I found out it's not available to download on here as the links expired, so I found it myself, hope it helps someone.
              Schematics and boardview attached below....
              06-25-2025, 05:02 AM
