ECS H61H2-A file V:2.0 need bios
  • bairambl
    • Dec 2022
    • Китай
    bios bin motherboard ECS H61H2-A file V:2.0 need if there is a skin please
    • 21853
    Re: bios bin file motherbord ECS H61H2-A V:1.0
    ECS provide a 6MB update,it is not a full bios image. https://www.ecs.com.tw/en/Product/Mo..._V2.0/download .Post your bios backup if you have one,then the 6MB update can be merged with your backup.
    • bairambl
      • Dec 2022
      • Китай
      Re: ECS H61H2-A file V:2.0 need bios
      the ecs h61h2-A v1.0 motherboard does not start the cooler rotates and stops cyclically, but the bios chip 25L3206E starts without a processor, why there may be a problem in the bios if there is a bios dump, please skin the bios chip, the chip is empty, there is nothing to prevent the bios
        • 21853
        Try this bios,it is 8MB so you will need an 8MB chip.The Rev 1.0 is 4MB, the Rev 2.0 is 8MB. The chip you have is only 4MB,its from another board.
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
        • maanee11
          Help to get Lenovo BIOS bin file for Thinkpad T560
          by maanee11
          Hello Everyone,
          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
          05-15-2022, 11:59 AM
