OLD HP Vectra VL400 - not start, beeps PSU in protected mode
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3590
    • slovakia
    Hello.
    Have this OLD HP Vectra VL400 with board mark D9820-60011 that not start. 2 beeps pointing to "PSU in protection mode" which leads me to nothing, because psu is ok and i dont find any short on board and when shorting green wire on ATX connector PSU start. it was replaced by normal psu but it dont have fan to CPU, so CPU was overheating. So where to find fault. board, CPU ? dont have schema or bv so i need help
    • 20807
    Re: OLD HP Vectra VL400 - not start, beeps PSU in protected mode
    fan fix
    https://community.hpe.com/t5/operati...3709353/page/3
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3590
      • slovakia
      i was told that new atx psu worked but dont have fan
        • 20807
        The HP PSU has a feedback pin, if the fan stops working a signal is sent to the PSU to shut down.Soldering the resistor mentioned fools the motherboard into thinking there is a load there and everything is ok
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3590
          • slovakia
          psu was replaced by not hp but normal atx, thats why it dont have right holes for cpu coling
            • 20807
            https://h30434.www3.hp.com/t5/Deskto...0/td-p/7664722
            "The old PSU has a line connected to the fan connector on the motherboard, and it was working, until the PSU died. So we do need a fan signal line (the "tachometric signal") from the PSU. Please see the link below:
            https://www.moddiy.com/pages/Fix-HP-515-Error.html*
            However, Moddiy does not have an adapter for our model."
            Solder a resistor and its good.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3590
              • slovakia
              Hmmm. i will check on it
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3590
                • slovakia
                tried but still the same. board have slot and original psu have connector, but custommer said that it worked ok for few months with casual ATX psu
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • DynaxSC
                  Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
                  by DynaxSC
                  I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
                  I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
                  Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
                  Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
                  05-04-2025, 12:08 PM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
