What capacitors are required to repair an EPOX EP8k3aE? Have some bulging, leaky caps and I'm gonna go ahead and do the replace this week. Thanks!
Epox EP8K3AE
Tags: None
Re: Epox EP8K3AE
Pics please? Low ESR caps from a Japanese manufacturer are required, values depend on what they currently are. Can't help you with values because I don't have an ep8k3ae. -
Re: Epox EP8K3AE
like chris said, you will need to tell us the values of the caps on the board. they are written on the side of the caps. We also need to know the brands of the caps to tell you what to replace.
the values will be written like 1000uf 6.3V. the brands is either a logo or written name on the caps.
please tell us all values 330uf and above
if you cant read some caps then provide pics. it would be good to see pics anyway.Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by RutsHi
I managed to knock off two capacitors on a EDM 033 board near the southbridge and BIOS chip.
Does anyone know the values of these capacitors?
by briztechHi can anyone identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF - Thanks
1 Photo -
Is there anybody here who could tell me what are the two caps marked bellow? Or atleast send me a picture of those two caps from their board. Size wise I think those will be 2200uF10v, the same as in the CPU VRM, but not sure.... -
by eryjusHello,
Channel: General Capacitor Questions & Issues
- Loading...
