GIGABYTE G1 Gaming GA-Z170X-Gaming 7, fails POST
  • yoctobunny
    • Jan 2011
    • 5
    I've had this PC going with an i7 6700K for years. The other day I walked over to it and it had something like, 'your bios has lost memory, do you want to load defaults or enter BIOS?'. I entered BIOS and it seemed fine, so I just rebooted. Came back later in the day and it will no longer POST. Usually it gets to LED code 32 before shutting itself off. Sometimes it will get past that.
    What I've tried:
    1. Swapping memory sticks to different slots, booting with 1 stick in every slot, booting with 1 stick of brand new memory in the slot closest to ATX power. All result in same behavior, usually makes it to code 32.
    2. Booting with no RAM whatsoever results in a code 55.
    3. Boot with an alternate PSU. Code 32.
    4. Removed CMOS battery, checked voltage (3.15ish). Held CMOS reset with battery out.
    5. Attempted to force dual bios backup read by holding power button and/or powering PSU off during post several times in a row.
    6. Force bios backup by shorting pins 1-6 on main bios chip. Note that when I do this, often the board does NOTHING when I flip the power switch. Power button on the board glows, no LED lights, no fans. Not sure if this is normal.
    7. Reseated CPU.
    8. Checked for visibly bulging capacitors everywhere.
    9. Pulled out GPU.
    10. Booting in single bios mode.
    11. My latest thought was that both bios chips had become corrupted.
    So I hooked up a Raspberry Pi with a SOIC8 alligator clips to the BIOS chips on the board, and manually flashed the newest BIOS available (V22) to the main chip with flashrom. This failed to work so I also tried (for no particular reason) V7 and V8. My last attempt was to flash both the main chip and the backup chip with V8 and boot in dual bios mode. This again resulted in code 32.
    I note that sometimes after flashing the bios like this, I make it past code 32 to something else that seems different every time. Sometimes 2b? Sometimes 24? 37? Can't be 100% sure this is because I am flashing bios and not just totally random and I am seeing correlations that aren't there.
    Also, sometimes when I would flash a bios, attempt to boot a few times, and then read the bios back from the chip, it would be different. Again, not sure how normal this is.
    Not sure what to do next other than just buy a new board. I'd be willing to attempt troubleshooting components with a multimeter if anyone has schematics, but I have zero experience doing this and not sure if I could even if I had the schematics.
    Any help or ideas would be appreciated, thanks!
  • isisyodin
    • Sep 2023
    Re: GIGABYTE G1 Gaming GA-Z170X-Gaming 7, fails POST
    I have the exact same issue. Same board. It was going strong and after a regular shutdown, if failed to post afterwards.
    Did you ever found what cap was bad?
    • anikin73
      • Mar 2022
      • 112
      • singapore
      If it runs different codes,likely pch is gone...
      • mikeybass
        by mikeybass
        04-23-2025, 04:30 PM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • Vesko356
        by Vesko356
        08-11-2023, 03:27 AM
      • nikovmiroslav
        Gigabyte A5 X1 Need Bios
        by nikovmiroslav
        Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
        Gigabyte A5 X1
        From motherboard:
        S/N: 1TNH55ER1350895
        P/N: 6-77-NH55ERQY-D02-2CGB
        On sticker from the back of the laptop:
        S/N: SN21351J000657...
        08-24-2025, 09:15 AM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
