Asus TUF 1660 Super PEX IC Chip ID
  • FreedomOne
    • Sep 2021
    • 5
    Hello, can anyone identify the model of the PEX ic chip on this Asus TUF 1660 super? The chip markings are 6J=7B
  • FreedomOne
    • Sep 2021
    • 5
    Re: Asus TUF 1660 Super PEX IC Chip ID
    Found from help on Discord:
    RT6220 is a synchronous Buck converter:
    https://www.richtek.com/m/Home/Produ...=richtekmobile
    • tmaster21
      • Feb 2021
      • 27
      • Portugal
      Hello ,Same problem here but mine its an tuf 1660 super with diferent chips ,they say AEAM 119 , by googling it, i found symylar Synchronous Buck Converters that are produced by Alpha-Omega, maybe this are too . but by the code i cant find. on pinout apear be exactly the same as RT6220.
      The pex voltage it's down and i reflow ,work until i shutdown ,so the GPU it's good ,i s just the buck converter dead.
      i have no ideas where to find thisClick image for larger version
        • 20855
        It might be a Monolithic Power NB671GQ https://www.badcaps.net/forum/troubl...20#post1482820
        Datasheet --> https://www.mouser.com/datasheet/2/2..._1-2559831.pdf
        • tmaster21
          • Feb 2021
          • 27
          • Portugal
          Originally posted by SMDFlea
          Might be!!.Thank you very much , i'm since 2021 register and didn't know this " marking codes" post. It goes directly to the firsts chrome's bookmarks,together with smd resistors codes 😁
          • noname2024
            • Aug 2024
            • 236
            • CỎ MỸ XỊN
            TRY Click image for larger version
ID:	3572052 Click image for larger version
            • ongobongo
              Asus ROG Ally - Super IO Chip replacement
              by ongobongo
              anyone here who has experience with replacing the super IO chip of an ROG ally?
              I have one on my bench which has a burnt super io (ITE 5125VG-192). On some devices the super-io downloads it's firmware from BIOS if it's empty. As i don't have a programmer for this chips i hope someone here has already changed the chip and can give me a hint if it's working with an empty chip if it needs external programming.
              Ongo
              11-17-2024, 11:27 AM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • BMCappelletti
              Asus Chromebox CN62 - wrong chip put on BIOS reader
              by BMCappelletti
              Long story short:
              - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
              - gave the computer to his son a couple years later
              - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
              - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
              (seems like the story was not that short)
              He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
              01-08-2025, 07:27 PM
              Thermal pad thickness for various laptop GPU / Graphics Cards
              ASUS Dual RTX 2070 OC 8GB
              ASUS ROG STRIX RTX 3080 OC
              ASUS ROG STRIX RTX 3090
              ASUS TUF Gaming RTX 3080 OC Edition
              ASUS TUF GTX 1660 S-O6G GAMING
              EVGA RTX 3060 Ti XC GAMING 8GB
              EVGA RTX 3060 XC GAMING 12GB GDDR6
              EVGA RTX 3080 FTW3 ULTRA GAMING
              EVGA RTX 3080 TI FTW3 ULTRA GAMING
              EVGA RTX 3090 XC3 ULTRA GAMING 24GB
              Gainward RTX 2080 Phoenix GS Specs
              Gainward RTX 3070 Phoenix 8GB
              Gainward RTX 3080 Ti Phoenix
              GIGABYTE AORUS RTX 3080 MASTER 10G
              02-09-2024, 08:08 AM
            • ebugs
              Asus laptop EC/SIO chip replacement
              by ebugs
              Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
              I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
              I found the EC chip...
              09-14-2024, 02:09 AM
