iMac logic board fan control question.
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    I have a 2010 A1311 iMac motherboard which was possibly damaged by lightning.
    One of the areas damaged was for the CPU fan control where inductor L5720 had exploded.
    Looking at the schematic (below) it is a 0603, and gives the value in ohms and seeing as I have no smd inductors here, it has been replaced with a 220Ω resistor. Without this, the fan will not work.
    The question is more related to the inductor next to it, L5701, which is part of the fans speed control.
    The schematic gives the value again at 220 Ω only it is a 0402 which is much smaller than anything I have here (and is placed on a super-fine trace which I'm not sure would even accomodate the resistors which I do have even if I soldered it on it's side). This one didn't explode but gives a measurement of only 4 ohms.
    Does anyone have any suggestions as to how to resolve this or I'll just leave it as-is and resolve any speed inconsistencies with the Macs Fan Control software?
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Re: iMac logic board fan control question.
    Thinking to just solder a fine wire with a 220R resisitor in the middle, insulated and stuck to the board...
    • piernov
      • Jan 2016
      • 4437
      • France
      Ferrite bead not resistor.
      • Crystaleyes
        • Sep 2021
        • 493
        • Brazil
        I know that it's supposed to be ferrite but not sure where I can get one. Looking online here in Brazil I can find 150Ω or 330Ω
        Is it so important that it is ferrite?
        • Crystaleyes
          • Sep 2021
          • 493
          • Brazil
          Have found a 220 Ω ferrite bead on another old iMac pcb but it's 0805 package is way too large, so shall do the wire trick mentioned earlier.
          Wish me luck!
          • Yanleb
            LG 60PK550 Logic Control Board EBR63450301
            by Yanleb
            Hi all, I just want to share the repair of my 60PK550-UA TV set.
            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
            C57: 3.30V
            C61:...
            07-20-2023, 12:38 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • ohren
            by ohren
            09-08-2023, 05:24 PM
          • korben_dallas
            Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
            by korben_dallas
            Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
            I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
            I'm new to soldering but the only feasible way to fix this issue is to do something myself.
            MY QUESTION:
            I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
            02-14-2024, 12:23 AM
