ASUS HD 6970 memory chip faulty
  • ostryo
    • Sep 2021
    • 17
    Hello i have a well known problem with the old radeon card. Two vertical stripes on the loading screen. The problem is, of course, some bad memory chip. Unfortunately all programs software you use work only from the 7000 series up. Anyone have any way to determine which memory chip is it? There are 8 of them and I would not like to guess.
    I think I saw a hardware method once. There was something like that you connected a line to GND and watched which lines went out.
    https://imgur.com/a/jPa06jK
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: ASUS HD 6970 memory chip faulty
    check for trace damage
    • ostryo
      • Sep 2021
      • 17
      what specific trace? Everything looks fine. I have already done dozens of such repairs on the 700 and R9 series. But we have the testing software there.
      • ll_r1d0_ll
        • Jan 2020
        • 12
        • Pakistan
        There you go
        • ostryo
          • Sep 2021
          • 17
          Originally posted by ll_r1d0_ll
          There you go
          Thank you very much. HD 6950 has 8 memory chips. First, I tried with the B0 bank and it was unchanged, it turned out to be a defective B1.
          Problem solved
          • ll_r1d0_ll
            • Jan 2020
            • 12
            • Pakistan
            Problem solved
            Great !! Enjoy
            • BMCappelletti
              Asus Chromebox CN62 - wrong chip put on BIOS reader
              by BMCappelletti
              Long story short:
              - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
              - gave the computer to his son a couple years later
              - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
              - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
              (seems like the story was not that short)
              He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
              01-08-2025, 07:27 PM
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
            • ebugs
              Asus laptop EC/SIO chip replacement
              by ebugs
              Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
              I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
              I found the EC chip...
              09-14-2024, 02:09 AM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • pengamat_hebat
              Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
              by pengamat_hebat
              I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
              Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
              However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
              I also tried applying 3.3V to pin 3, but it still didn't work.
              I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
              03-25-2025, 04:13 AM
