Ripped component on XFX Radeon RX 570
  • Dowhile
    • Sep 2020
    • 28
    • Italia
    Hi guys, i have this board with a missing component.. i have no schematics for this card. do you have any ideas? the marking is U4 and it has 6 legs
    Thx
  • Zsombi114
    • Apr 2022
    • 23
    • Romania
    Re: Ripped component on XFX Radeon RX 570
    Hi! Firstly, you have to repair those pads. As I can see, there are 3 missing pads. Besides, I am not sure Its missing. I have an Rx 5600 xt and the U4 is missing from the card. (it is next to the bios chip like on your card). Try to solder those resistors correctly. I can see at least 2 badly soldered components.
    • Dowhile
      • Sep 2020
      • 28
      • Italia
      Man i need the component missing. Soldering the resistors and rebuild the pads is an easy job
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3580
        • slovakia
        Here u go. Marking is B7AA
        • Dowhile
          • Sep 2020
          • 28
          • Italia
          i love u my friend!
            AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
            The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
            10-01-2024, 12:46 PM
            AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
            The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
            10-01-2024, 01:07 PM
            AMD Radeon RX 470 / RX 580 Schematic & Board View
            The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
            10-01-2024, 12:52 PM
          • mikay786
            820-00138-A - Advice on how to fix corroded missing / pads
            by mikay786
            Working on this a MacBook i purchased, has some corrosion around what according to the schematic is SSD CURRENT SENSE circuit. I've got 3 missing pads
            The pad left side of R3742, where would be best to run a jumper wire too?
            I assume the other 2 missing pads should be simple enough with top C3701 pad which appears to be connected to the other components on the same plane. Pad on right side of R3742 just need to make sure is connected to trace.
            Mainly struggling with left pad of R3742 and where to run a jumper, maybe a via as appears to go to multiple...
            12-20-2023, 07:14 PM
          • GraphicMan
            21SF8XEL 21" CRT TV ripped pads, PCB (kd -331 (v1.0) sh12144)
            by GraphicMan
            Hello
            someone forced the STR (FSCQ1265RT) out and ripped the pads off
            now I need to reconstruct the tracks but I dont know how it will go (no prior pics before the damage)
            Attached the affected area pic, pic 2 is the best i could found online for the same area
            the pins from 1 to 5 are for the STR
            any help is appreciated
            Thanks...
            06-07-2025, 02:35 PM
