Gigabyte RX 6800 XT pciex lines caps value and size
  • Opacky
    • Oct 2021
    • 8
    • Serbia
    Guys does anyone know Gigabyte RX 6800 XT pciex lines caps value and size? They seem even smaller than 0201 to me?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3593
    • slovakia
    Re: Gigabyte RX 6800 XT pciex lines caps value and size
    why dont u just measure size, remove and measure capacity?
    • Opacky
      • Oct 2021
      • 8
      • Serbia
      They are 220nF that is not the problem but I was surprised by the size of them. I ended up using standard size 0402 It was tight fit but ok. Thanks for response anyway!
      • sect-sin
        Gigabyte XT 6800 XT Aorus Master BIOS needed
        by sect-sin
        I have an AORUS MASTER RX 6800 XT (non USB-C version), and my problem is that FUSION RGB is not working, it is not finding the GPU, and the RGB lights are off. There is a new firmware on the Gigabyte site which is supposed to fix this exact issue, but their Firmware upgrade does not work (I just get the highly unhelpful Erasing Flash Failed message when trying to update). I tried various internet-recommended software fixes to address this, but nothing helped, the factory Gigabyte EXE refuses to flash the BIOS.
        My last resort would really be flashing the...
        10-13-2023, 06:08 AM
        Thermal pad thickness for various laptop GPU / Graphics Cards
        ASUS Dual RTX 2070 OC 8GB
        ASUS ROG STRIX RTX 3080 OC
        ASUS ROG STRIX RTX 3090
        ASUS TUF Gaming RTX 3080 OC Edition
        ASUS TUF GTX 1660 S-O6G GAMING
        EVGA RTX 3060 Ti XC GAMING 8GB
        EVGA RTX 3060 XC GAMING 12GB GDDR6
        EVGA RTX 3080 FTW3 ULTRA GAMING
        EVGA RTX 3080 TI FTW3 ULTRA GAMING
        EVGA RTX 3090 XC3 ULTRA GAMING 24GB
        Gainward RTX 2080 Phoenix GS Specs
        Gainward RTX 3070 Phoenix 8GB
        Gainward RTX 3080 Ti Phoenix
        GIGABYTE AORUS RTX 3080 MASTER 10G
        02-09-2024, 08:08 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
        AMD Radeon RX 6800 XT (RX6800XT) Schematic & Board View
        The Radeon RX 6800 XT is a high-end graphics card by AMD, launched on October 28th, 2020. Built on the 7 nm process, and based on the Navi 21 graphics processor, in its Navi 21 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 6800 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 21 graphics processor is a large chip with a die area of 520 mm² and 26,800...
        10-01-2024, 12:17 PM
      • DynaxSC
        GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
        by DynaxSC
        I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
        General test conditions:
        - Tested with Core i5 6500 and Core I7 6700K - no difference
        - Default BIOS settings, but tried also altering several memory setting - does not change anything
        What is wrong:
        With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
        When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
        03-21-2025, 06:23 PM
