Guys does anyone know Gigabyte RX 6800 XT pciex lines caps value and size? They seem even smaller than 0201 to me?
by sect-sinHi everyone,
I have an AORUS MASTER RX 6800 XT (non USB-C version), and my problem is that FUSION RGB is not working, it is not finding the GPU, and the RGB lights are off. There is a new firmware on the Gigabyte site which is supposed to fix this exact issue, but their Firmware upgrade does not work (I just get the highly unhelpful Erasing Flash Failed message when trying to update). I tried various internet-recommended software fixes to address this, but nothing helped, the factory Gigabyte EXE refuses to flash the BIOS.
My last resort would really be flashing the...-
Thermal pad thickness for various laptop GPU / Graphics Cards
ASUS Dual RTX 2070 OC 8GB
ASUS ROG STRIX RTX 3080 OC
ASUS ROG STRIX RTX 3090
ASUS TUF Gaming RTX 3080 OC Edition
ASUS TUF GTX 1660 S-O6G GAMING
EVGA RTX 3060 Ti XC GAMING 8GB
EVGA RTX 3060 XC GAMING 12GB GDDR6
EVGA RTX 3080 FTW3 ULTRA GAMING
EVGA RTX 3080 TI FTW3 ULTRA GAMING
EVGA RTX 3090 XC3 ULTRA GAMING 24GB
Gainward RTX 2080 Phoenix GS Specs
Gainward RTX 3070 Phoenix 8GB
Gainward RTX 3080 Ti Phoenix
GIGABYTE AORUS RTX 3080 MASTER 10G
Channel: Schematics and Boardviews
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
AMD Radeon RX 6800 XT (RX6800XT) Schematic & Board View
The Radeon RX 6800 XT is a high-end graphics card by AMD, launched on October 28th, 2020. Built on the 7 nm process, and based on the Navi 21 graphics processor, in its Navi 21 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 6800 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 21 graphics processor is a large chip with a die area of 520 mm² and 26,800...-
by DynaxSCHi,
I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
General test conditions:
- Tested with Core i5 6500 and Core I7 6700K - no difference
- Default BIOS settings, but tried also altering several memory setting - does not change anything
What is wrong:
With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2... - Loading...
