MP1469 Step Down Cenverter EN Voltage?
  • pebyungmin
    • Dec 2021
    • 5
    • south Korea
    The VCC supply from Dr Mos is not working because the rail is not working.
    1 and 4 are 12V
    2, 3, and 6 are 0V
    No. 5 EN is 6.5V.
    I need to check whether EN's 6.5V is normal or not.
    Even after replacing the chip, the symptoms are the same.
  • black0ut
    • Aug 2020
    • 7
    • Austria
    Re: MP1469 Step Down Cenverter EN Voltage?
    Hi yes this seems normal, on page 10 you can see the explanation for enable
    Enable
    EN is a digital control pin that turns the
    regulator on and off: Drive EN HIGH to turn on
    the regulator, drive it LOW to turn it off. An
    internal 1MΩ resistor from EN to GND allows
    EN to float to shut down the chip.
    The EN pin is clamped internally using a 6.5V
    series-Zener-diode as shown in Figure 2.
    Connecting the EN input pin through a pullup
    resistor to the voltage on the VIN pin limits the
    EN input current to less than 100μA.
    • pebyungmin
      • Dec 2021
      • 5
      • south Korea
      Thank you for answer. But is there no output when all voltages are present? Anything more to check?
      • Instafixx
        Macbook A2179 820-01958
        by Instafixx
        Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
        The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
        I checked the Power Sequences below and found this -
        Once a valid external power source (Charger or battery) is connected, the following rails will come online.
        PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
        PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
        05-20-2023, 05:19 AM
      • crnimrki
        MacBook Pro 820-2327-A, have green light, charge, have normal voltage, no chime
        by crnimrki
        MacBook Pro 820-2327-A, have green light, charge, have normal voltage, no chime. On power on fan spins 5 seconds then stop and again spin and stay spinning.
        CPU Warm, DVD Drive not spinning, Mouse on USB Port inactive. No beeps without RAM DIMM-s.
        PPBUS_G3H - 12.55V without battery, 11.99 with battery charging
        PP3V42_G3H3.39V
        PPVCORE_S0_CPU - 0.98
        RAM VOLTAGE 1.49
        Where to search...
        01-02-2025, 12:51 PM
      • alro7779
        MOSFET? Is its voltage reading normal?
        by alro7779
        Hello, guys!
        Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can...
        06-19-2025, 08:19 AM
      • harp
        can you fix XL4015 Step-Down CC/VC low voltage problem
        by harp
        I notice some issue with handy XL4015 Step-Down DC Module with CV/CC Control, so I ask if that can be fix or lower/minimise effect...
        Its about that module cant hold CC when voltage is set less than 1.7v
        If you have that module, please confirm that.
        Here is visualisation table for fixed 100mA CC, measuring output in short :
        set 3.0v - 100mA/0.00v in short
        set 2.0v - 100mA/0.00v in short
        set 1.8v - 100mA/0.00v in short
        set 1.7v - 100mA/0.00v in short
        set 1.6v - 300mA/0.00v in short
        set 1.5v - 900mA/0.00v in short...
        03-02-2023, 10:09 AM
      • rutgerv
        Acer Swift 3 SF314-42 not powering up
        by rutgerv
        Dear all,
        For a friend I'm trying to repair an Acer Swift 3 laptop (SF314-42). I'm not a professional, but have some experience (both as amateur and professional) in working with electronic design and repair of musical instruments.
        The issue with the Acer laptop is the following:
        It was bought new and used (not heavily) at home for about three years. After normal use, it was put to sleep, connected to charger and left over night (just like any other day). The next morning, the laptop would not wake up from sleep. Instead, when pressing the power button, the power...
        08-02-2024, 06:59 AM
