Asus RTX 2070 (Please help!)
  • hamed57
    • Nov 2015
    Hi, I am working on a RTX 2070 which has a short on the 12V line.
    I pin pointed the short to a mosfet. But the mosfet is out of stock everywhere. Can you please give me an alternative for this mosfet?
    https://www.mouser.ca/ProductDetail/595-CSD95481RWJT
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Re: Asus RTX 2070 (Please help!)
    no problem on ali
    • dqtech
      Asus X455L Short Mosfet
      by dqtech
      I got this laptop from friend with problem short 19v....when i check this 2 mosfet getting short...i remove that mosfet and confirm that mosfet is short...
      and check that 2 capacitor PC9009 and PC9004 pad is also short...already check where that capacitor goes and came from but cannot find the main problem...please help
      08-09-2022, 08:53 PM
    • questore
      HP OMEN 15-ce012nh give error code 5long 3 short after CPU LOW SIDE MOSFET BURN
      by questore
      Hello everyone.
      Someone brought this poor hp in.
      All power rails had normal resistances so i turned it on. Instant power cutoff...
      First mosfet was shorted so replaced it...
      After that I have tryed to start since no short was on the main power rail. the CPU middle dual mosfet heated up and protection shut down the laptop.
      After investigating i have found that when the mosftet turning on then the mostfet got instantly hot (not the CPU)
      Removed the faulty mosfet. -> now laptop turns on CPU mildly gets hot but laptop gives the common 5 long 3 short LED...
      08-25-2025, 10:09 AM
    • AppleLover123
      Asus X712EA 3 volts after the first mosfet
      by AppleLover123
      Hey guys,
      i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
      I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
      Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
      I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
      Now i thought something...
      12-15-2024, 07:49 AM
    • Scotchmist
      Asus GA502D keeps blowing mosfet
      by Scotchmist
      I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
      I have removed the mosfet and can run the laptop no problem
      The MOSFET is FDPC5018SG
      Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
      08-24-2024, 02:23 PM
    • jkyoho
      ASUS TUF FA506IV-AS76 vram mosfet short, then battery cant charge
      by jkyoho
      I recently fixed a FA506IV cam with Vram mosfet short on Vin(19v)to ground. Got both mosfet replaced and now laptop could turns on and GPU everything works but battery not charging. Battery status shows 100% on both BIOS page and Windows system.
      Measured voltage got 0.3v on battery red lead not going up. charging mosfet gate low and 19v not passing through inductor.
      I also tried dc bench supply 14v charge directly onto battery but seems not drawing anthing.
      Any idea?
      07-11-2022, 03:39 PM
