ECS LS45M v1.0
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    ECS LS45M v1.0
    I have two of these
    One is a v2. pcb, the other (giving me problems) is a v1. pcb
    The issue is with the keyboard.
    AT POST, sometimes the mobo will issue a beep or beeps, flash the num, alpha and scroll lock leds and I will lose the keyboard.
    Naturally enough I thought this was down to bad caps
    Sure enough, albeit the caps did not show bad phy. signs or bad ESR,
    I replaced both the CPU I/P and O/P VRM as well as all the 10V 1000uF
    caps on the mobo. All the other caps are 470uF or under.
    Post recap, the issue still persists.
    I tried testing the ESR all of the remaining caps and found four or five
    that had suspect ESR in cct. I took them out and tested the ESR again.
    This confirmed my suspisions.
    Checked the solder work on the superIO IC - this is good (appears ok).
    Any other suggestions from forum members?
    by momaka
    03-12-2025, 03:42 PM
    by momaka
    03-15-2023, 10:17 PM
  • eryjus
    by eryjus
    05-10-2023, 11:21 AM
  • goodpsusearch
    Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
    by goodpsusearch
    Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
    First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
    05-05-2024, 02:04 PM
  • bcstedt
    LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
    by bcstedt
    LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
    Problem:
    On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
    It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
    01-18-2024, 01:03 PM
