GV-N108TGAMING OC-11GD thermal pad thickness
  • FluffehBunneh
    • Mar 2022
    • 4
    does anyone no the termalpad thicknesses for a GV-N108TGAMING OC-11GD gpu Gigabyte claims they dont no
  • mon2
    • Dec 2019
    • 14659
    Re: GV-N108TGAMING OC-11GD thermal pad thickness
    Thermal pads to use with the heatsink?
    We refurb imac and macbooks often. In the process we use the thermal pads from T-global. You can source these from Digikey. Search for them on their website or the factory in Taiwan. In short, the better the thermals of the pad, the more costly. We love the product and it works well. Compare the thermals from other shops on Amazon, T-global will not be beat.
    Buy what you can afford. Be sure to apply on a clean and flat surface so the heat is dissipated.
    Hope this helps.
    • benwaterson
      • Aug 2008
      • 202
      • United Kingdom
      Have you got a picture of the bottom of the heatsink? If its the same as an Aorus card then I can measure one of the ones I have here
