does anyone no the termalpad thicknesses for a GV-N108TGAMING OC-11GD gpu Gigabyte claims they dont no
GV-N108TGAMING OC-11GD thermal pad thickness
Tags: None
Re: GV-N108TGAMING OC-11GD thermal pad thickness
Thermal pads to use with the heatsink?
We refurb imac and macbooks often. In the process we use the thermal pads from T-global. You can source these from Digikey. Search for them on their website or the factory in Taiwan. In short, the better the thermals of the pad, the more costly. We love the product and it works well. Compare the thermals from other shops on Amazon, T-global will not be beat.
Buy what you can afford. Be sure to apply on a clean and flat surface so the heat is dissipated.
Hope this helps. -
by sancho76Hi, somebody knows the thickness of thermal pads for M15 R1? Or if someone have this Alienware model, can take measure for original thermal pads.
Thermal pad thickness for various laptop GPU / Graphics Cards
ASUS Dual RTX 2070 OC 8GB
ASUS ROG STRIX RTX 3080 OC
ASUS ROG STRIX RTX 3090
ASUS TUF Gaming RTX 3080 OC Edition
ASUS TUF GTX 1660 S-O6G GAMING
EVGA RTX 3060 Ti XC GAMING 8GB
EVGA RTX 3060 XC GAMING 12GB GDDR6
EVGA RTX 3080 FTW3 ULTRA GAMING
EVGA RTX 3080 TI FTW3 ULTRA GAMING
EVGA RTX 3090 XC3 ULTRA GAMING 24GB
Gainward RTX 2080 Phoenix GS Specs
Gainward RTX 3070 Phoenix 8GB
Gainward RTX 3080 Ti Phoenix
GIGABYTE AORUS RTX 3080 MASTER 10G
Channel: Schematics and Boardviews
02-09-2024, 08:08 AM -
by GcnewbieForgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
I opened the...03-29-2024, 06:55 AM -
by Veyron7887Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
by caspianDear members,
I have got an ordinary gray thermal paste that has no name/model on the box.
I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
Is it safe to leave the thermal paste on the pins?
I guess the thermal paste... - Loading...
