AXRX Vega 56 8GBHBM2-2D2HD/OC - memory corruption. can be something done?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3590
    • slovakia
    Have this AXRX Vega 56 8GBHBM2-2D2HD/OC tha hve looks like memory corruption.
    as memory is build to GPU can be something done, like reball?
    pattern of artefact is changing on mode of picture. gpu-z shows no bandwidth or frequency
  • gt403cyl
    • Jan 2017
    • 35
    Re: AXRX Vega 56 8GBHBM2-2D2HD/OC - memory corruption. can be something done?
    With HBM it's one and done.
    Rip.
      AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
      The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
      10-01-2024, 01:07 PM
      ASUS D515DA R7-3700U, 15.6" FHD vIPS, 512GB SSD, 8GB RAM, VEGA 10, W10H, 1YR Notebook Specification for Upgrade or Repair
      This specification for the ASUS D515DA R7-3700U, 15.6" FHD vIPS, 512GB SSD, 8GB RAM, VEGA 10, W10H, 1YR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the D515DA R7-3700U, 15.6" FHD vIPS, 512GB SSD, 8GB RAM, VEGA 10, W10H, 1YR boardview and D515DA R7-3700U, 15.6" FHD vIPS, 512GB SSD, 8GB RAM, VEGA 10, W10H, 1YR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
      09-06-2024, 10:50 PM
    • odtech
      Gigabyte RX Vega 56 8Gig component ID help
      by odtech
      So I have this Gigabyte RX Vega 56 8Gig that has a open capacitor near the VRM's. The capacitor is visibly damaged. It seems the schematic and boardview for it is not available.
      Does someone happen to have one to check the capacitance of that cap?
      C708 as in the picture. Unfortunaly the original backplate with the stickers on is not with the card so I can't tell the exact model....
      04-16-2025, 05:18 PM
    • jadao
      Acer Predator Helios Neo 16 BIOS corruption suspected
      by jadao
      Status: Power on with fan but no post dead brain no usb activity, bios corruption suspected
      S/N: NHQMAAA0033150C8367600
      SNID: 31505125476
      MB: DAZGRMB2AC0 REV C
      Can you please fix it?
      Thank you!​...
      09-12-2024, 09:24 PM
    • Borges
      GIGABYTE VEGA 56 8GB bad voltages on 1.8V Rail
      by Borges
      I currently have a Vega 56 that won't turn on. I have measured the resistances and continuity and there seems to be no shortage on any of the rails of the GPU.
      However, when I plug the Vega 56 into my pc an try to measure the voltages, everything seems fine until the 1,8V rail. Consequently this affects my Vcore, Memory and PEX Voltages. Therefore I believe that the problem is betweeen my 5v rail and 1,8V rail (the Magic IR0 inductor on the top left of the GPU is the 1,8V reference I use and the R22 below the VRMs is the 5V reference).
      My issue is that I have been...
      12-18-2021, 03:36 PM
