Gigabyte RX Vega 56 8Gig component ID help
  • odtech
    • Jul 2023
    • 49
    • South Africa
    So I have this Gigabyte RX Vega 56 8Gig that has a open capacitor near the VRM's. The capacitor is visibly damaged. It seems the schematic and boardview for it is not available.
    Does someone happen to have one to check the capacitance of that cap?
    C708 as in the picture. Unfortunaly the original backplate with the stickers on is not with the card so I can't tell the exact model.
    AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
    The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
    10-01-2024, 01:07 PM
    Thermal pad thickness for various laptop GPU / Graphics Cards
    ASUS Dual RTX 2070 OC 8GB
    ASUS ROG STRIX RTX 3080 OC
    ASUS ROG STRIX RTX 3090
    ASUS TUF Gaming RTX 3080 OC Edition
    ASUS TUF GTX 1660 S-O6G GAMING
    EVGA RTX 3060 Ti XC GAMING 8GB
    EVGA RTX 3060 XC GAMING 12GB GDDR6
    EVGA RTX 3080 FTW3 ULTRA GAMING
    EVGA RTX 3080 TI FTW3 ULTRA GAMING
    EVGA RTX 3090 XC3 ULTRA GAMING 24GB
    Gainward RTX 2080 Phoenix GS Specs
    Gainward RTX 3070 Phoenix 8GB
    Gainward RTX 3080 Ti Phoenix
    GIGABYTE AORUS RTX 3080 MASTER 10G
    02-09-2024, 08:08 AM
    ASUS D515DA R7-3700U, 15.6" FHD vIPS, 512GB SSD, 8GB RAM, VEGA 10, W10H, 1YR Notebook Specification for Upgrade or Repair
    This specification for the ASUS D515DA R7-3700U, 15.6" FHD vIPS, 512GB SSD, 8GB RAM, VEGA 10, W10H, 1YR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the D515DA R7-3700U, 15.6" FHD vIPS, 512GB SSD, 8GB RAM, VEGA 10, W10H, 1YR boardview and D515DA R7-3700U, 15.6" FHD vIPS, 512GB SSD, 8GB RAM, VEGA 10, W10H, 1YR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
    09-06-2024, 10:50 PM
  • DynaxSC
    GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
    by DynaxSC
    I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
    General test conditions:
    - Tested with Core i5 6500 and Core I7 6700K - no difference
    - Default BIOS settings, but tried also altering several memory setting - does not change anything
    What is wrong:
    With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
    When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
    03-21-2025, 06:23 PM
  • Borges
    GIGABYTE VEGA 56 8GB bad voltages on 1.8V Rail
    by Borges
    I currently have a Vega 56 that won't turn on. I have measured the resistances and continuity and there seems to be no shortage on any of the rails of the GPU.
    However, when I plug the Vega 56 into my pc an try to measure the voltages, everything seems fine until the 1,8V rail. Consequently this affects my Vcore, Memory and PEX Voltages. Therefore I believe that the problem is betweeen my 5v rail and 1,8V rail (the Magic IR0 inductor on the top left of the GPU is the 1,8V reference I use and the R22 below the VRMs is the 5V reference).
    My issue is that I have been...
    12-18-2021, 03:36 PM
