Asus prime B365-Plus No PS2 or USB
  • Fabbrone
    • Jun 2015
    • 158
    • italy
    Hey
    On this mobo with no power to USB or PS2 Port.
    what would you suggest?
    Thank
    fabbrone
  • DynaxSC
    • Apr 2021
    • 457
    • Poland
    Re: Asus prime B365-Plus No PS2 or USB
    Check any Bios setting for swithed off ports, check 5V regulator supplying the USB/PS2 (usually an analogue one) and if the supply voltage for it is presesent (probably 12V). Check for short after the 5V regulator. Check any recovering fuses or any 0 ohms serial resistors in the 5V power lane for discontinuity if present. Check any switching mosfets between the regulator and USB. Check ESD surge protectors on USB data lines for shorts (very small 6 pin dual in-line devices near the USB Ports), they go short on a surge to protect the chipset and must be replaced (they are usually devices like IP4220CZ6, case type: SO6 (SOT457)).
    • Pedro Ramírez
      NEED BIOS ASUS PRIME H310M -E R2
      by Pedro Ramírez
      Hi friends, I need help with the BIOS on an Asus Prime H310M motherboard - E R2, no video when turned on. I've attached the original backup....
      Yesterday, 03:43 PM
    • DynaxSC
      Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
      by DynaxSC
      Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
      For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
      06-10-2023, 11:30 AM
    • RotVik
      ASUS PRIME B550M-A AC weird behavior
      by RotVik
      Hello, I need a little help
      I got an ASUS PRIME B550M-A AC Motherboard, bad BIOS, it wont display or boot, unless I did CMOS Restart first, after that It will boot but if I modified the configuration of the bios and saved it ,again no image
      I got the BIOS .CAP file from ASUS official support, used a tool called ASUS CAP to BIN, and programmed it to the IC, soldered to the board and got it to boot correctly, all the way to Windows, but now the CPU fan stays at full speed all the time and if I try to power it off with power button it will restart instead, and there are...
      05-01-2025, 04:59 PM
    • taurtnt
      ASUS Prime Z490-P boardview
      by taurtnt
      need ASUS Prime Z490-P boardview diagram
      Hi, I have an ASUS Prime Z490-P motherboard, it doesn't start and I need the boardview diagram, if anyone can help me
      01-24-2025, 10:26 AM
    • lezsimply
      Low resistance reading on 3v line, Asus Prime H310M-A R2.0 desktop motherboard
      by lezsimply
      Hello Everyone and Good Day,
      I've got an issue with this desktop motherboard. It does not power on, Asus Prime H310M-A R2.0. I tested 33ohms reading on 3v line on the ATX connector. It beeps on continuity mode. I tried injecting voltage from 0.9v at 1.5amps and no current being drawn. I raised the voltage to 3v @ 4amps and now I only get 22mA on current. I checked with thermal camera and there is no part heating up. I'm afraid of going further the safe voltage. What could possibly causing the line to be shorted. 5vsb has no short. I get 0.9v on positive pin of power switch. There's...
      11-22-2024, 03:14 AM
