MSI B450 TOMAHAWK MAX 2 doesn't boot with CPU
  • xfor62
    • Feb 2019
    • 14
    • France
    i'm new and come here because i need help to try to repair a mobo for my nephew.
    He bought msi b450 tomahawk max 2 but this board doesn't boot with a CPU on the board.
    Even, if the CPU is on the board, the LED system blink and never boot.
    Without he CPU, the board goes ON and the voltage seems good.
    I just have a doubt on SYS_FAN4, i have the next voltages 0V (pin 1), 12.12V (pin 2), 10.7V (pin 3) and 5V (pin 4).
    All others Fans (sys/cpu/pump), i have on pin 2 : 6,3 V, others voltages are the same as above.
    can anybody say me if those voltages are corrects or not for each fan in particular on pin 2 for sys-fan 4.
    As the problem is occurring when i put the CPU on the board , and i have not for the moment another CPU, i'm trying to check if the board is ok by testing voltage.
    thanks in advance for your help
  • xfor62
    • Feb 2019
    • 14
    • France
    Re: MSI B450 TOMAHAWK MAX 2 doesn't boot with CPU
    Test | ATX...... | CPU (EPS.12V). | CPU............. | RAM............. | Result............... | EZ.LED.On............. | LED.Off
    1... | Connected | Not connected. | Out of the board | Out of the board | OK, good voltages.... | CPU................... | RAM/VGA/BOOT
    2... | Connected | Connected..... | Out of the board | Out of the board | OK, good voltages.... | CPU................... | RAM/VGA/BOOT
    3... | Connected | Not connected. | On the board.... | Out of the board | KO, variable voltages | RAM/VGA/BOOT blinking. | CPU
    4... | Connected | Connected..... | On the board.... | Out of the board | KO, variable voltages | RAM/VGA/BOOT blinking. | CPU
    5... | Connected | Connected..... | Out of the board | On the board.... | OK, good voltages.... | CPU................... | RAM/VGA/BOOT
    so i think the CPU is causing the boot problem.
    We have tested the RAM in another motherboard, and the RAM works.
    • foshland
      • Jan 2017
      • 122
      • Spain
      Have you tested the power supply in another pc? maybe its the problem....
      • xfor62
        • Feb 2019
        • 14
        • France
        no, it's a new i bought this week, it's a cooler master mwe 550W bronze.
        i had previously a noname PSU and i've doubt about this noname PSU, this is why i bought a new one PSU with a known brand name.
        So i hope, it's a good one.
        • xfor62
          • Feb 2019
          • 14
          • France
          I checked voltage at different points on the MB and found nothing wrong (with CPU out).
          ATX Voltage OK
          DDR voltage 1.2V OK
          USB 5V OK, i plug a smartphone and it is charging
          USB flash is ok because we can use flash button to update BIOS (around 7 minutes with a ROM file from MSI website)
          BIOS voltage 1.8V OK
          So i will look at cpu parts
          if somebody has bdv file for B450 Tomahawk Max 2 (boardview file) because i have only schematics view
          • Benass
            • Oct 2020
            • 73
            • Uk
            Please consider updating bios, There is a small chance your bios do not support the cpu. ( I might be wrong)
            • DynaxSC
              • Apr 2021
              • 475
              • Poland
              Have you checked also the 0,6V memory voltage ?
              Correct CPU generation for this board ?
              Can you check the CPU on another board ?
              CPU socket pins are OK ?
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                Do you have Vcore when the CPU is fitted?
                Could you post the schematic here please, I don't have that one.
                Rich
                Follow me on YouTube
                Learn Electronics Repair
                • xfor62
                  • Feb 2019
                  • 14
                  • France
                  i've done it, without issue (around 7minutes)
                  And from MSI website, the CPU Ryzen 5 3400G is marked as compatible
                  thks
                  • xfor62
                    • Feb 2019
                    • 14
                    • France
                    i will check voltage.
                    CPU generation is correct for me, Ryzen 5 3400G
                    I didn't have another board for the moment
                    CPU socket seems ok, but i didn't disassembly it
                    • xfor62
                      • Feb 2019
                      • 14
                      • France
                      Rich
                      please find schematics in attached file
                      • xfor62
                        • Feb 2019
                        • 14
                        • France
                        without CPU, under the socket, i found on different points either 1.1 v either 1.2 v
                        • xfor62
                          • Feb 2019
                          • 14
                          • France
                          few news, i've tested an athlon 3000g and all works fine.
                          So the default is the CPU.
                          MB, RAM is ok
                          • xfor62
                            • Feb 2019
                            • 14
                            • France
                            i've tested CPU, and short between ground and vddcr_cpu, vddio_mem, vddcr_soc .....
                            CPU is dead....
                            Regards
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
                            • howardc64
                              by howardc64
                              07-24-2025, 05:17 PM
                            • pavski
                              Board view and schematics for MSI Mag z490 tomahawk board
                              by pavski
                              The MSI Mag z490 tomahawk board is not responding to pressing the switch button. There is voltage supplied to BIOS and superio but I would like to trace it. Perhaps somebody could share board view and schematics? Thank you....
                              06-01-2024, 12:49 PM
                            • Hakuu
                              by Hakuu
                              Hi There,
                              More Details
                              TV Model - LG OLED77G1PUA
                              07-12-2023, 02:37 PM
