iMac 820-3481 no power.
  • guruji
    • Oct 2012
    • 122
    • India
    hello
    I have an iMac works perfectly without rtc cell .the moment I put the cell back and the I see on S5 lite and then go to power on the S5 disappears for a sec but does not power on.If anyone can help me where I should look for problem.
    thanks
  • AlbinoKrait
    • Jan 2022
    • 7
    Re: iMac 820-3481 no power.
    Just curious, have tried using a different battery and doing an NVRAM/PRAM reset? Sometimes it needs it cleared/reset with hardware a change (the RTC cell counts with this) or you could have a battery that doesn't have enough voltage to pass the startup diagnostics performed with every boot/power on.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
      03-31-2024, 02:12 PM
    • ryogadan78
      iMac A1418 - No LED, no power after overvoltage on Ethernet port
      by ryogadan78
      Hi guys, I need your help again.
      I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
      When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
      06-10-2025, 03:49 AM
