Logitech G935 headset no audio on one side
  • ntec
    • Jun 2020
    • 55
    I have a logitech g935 headset and the weird issue is that one side does not work on wireless but when plugged in with the 3.5mm cable it works fine so I don't think it's the wiring?. I have already updated the firmware and checked all the windows audio settings to make sure the balance was equal etc so I don't think it's a software issue. Should I assume it's a logic board issue? I did take it apart but not sure where to troubleshoot on the logic board. I do have a fluke meter and familiar with soldering if needed.
  • samson7point1@yahoo.com
    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
    by samson7point1@yahoo.com
    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
    The player processes the audio signal using two different reference frequencies. The "R"...
    04-30-2024, 11:22 AM
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • jimanez11
    Sennheiser Momentum M2 AEBT Headphones
    by jimanez11
    Have an issue with my momentum wireless headphones. Bought them on ebay to try out repairing them - have done component level repairs on laptops and other small devices, so figured I would give it a shot - but I know very little about audio circuits and troubleshooting - so please forgive my lack of basic terminology knowledge and any help is appreciated.
    An overview of the symptoms is listed below with a more detailed outline after that:
    - Immediately on power on - slight static in right side of headphones
    - Static only lasts for 45 seconds to a minute
    07-16-2021, 09:36 AM
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
  • i_am_patch
    Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
    by i_am_patch
    Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
    04-30-2024, 08:20 PM
