Stuck RESET on MSI P965 NEO after Recap
  • xnRS
    • Feb 2021
    • 85
    • Belarus
    I have an MSI P965 neo which I recapped as 70% of caps were bulged(KZG tho). Before recap it posted and stuck on DRAM error. At some point, after recap it stopped posting, post card showing 00 and RESET LED. What can it be ?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: Stuck RESET on MSI P965 NEO after Recap
    Well it 'can' be Bad soldering causing a short, or broken tracks or vias?
    Why not post some pics?
    Follow me on YouTube
    Learn Electronics Repair
    • kotel studios
      ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
      by kotel studios
      Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
      Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
      I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
      12-14-2024, 10:48 AM
    • Stunt
      Hp Laptop Stuck on Hp protected by hp sure start screen
      by Stunt
      Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
      I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
      I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
      Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
      screen that's it and stuck there. I left it until the following day and i still...
      09-02-2025, 01:51 PM
    • sheffieldyorky
      ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
      by sheffieldyorky
      Hey there people
      While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
      This is what I tried, but not in any order.
      Google
      YouTube
      BIOS
      Command Prompt (administrator privileges)
      On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
      Yesterday, 02:22 AM
    • stormanimal83
      Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
      by stormanimal83
      Hey....
      Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
      my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
      01-18-2024, 02:15 PM
    • ekozeko333
      by ekozeko333
      🧠 What I’ve Done So Far
      Flashed...
      06-21-2025, 02:48 AM
