Biostar Hi-Fi A88S3E MOSFETs Not Turning On
  • decayed.cell
    • Sep 2018
    • 11
    I'm having an issue with this motherboard where it will turn on but the debug card says 00, with a red light on motherboard.
    I've checked the voltage rails and they all appear to be there. I'm getting 12V at Drain on the top row of MOSFETs. The gates all are 0V, so the Source is 0V.
    To the left there is a gate driver ISL6208BCRZ, marked as PU2 on the motherboard - this is getting 5V in on VCC. This driver is connected to the three MOSFET pairs on the left. Its also reading approximately 0.5V voltage drop across VCC and BOOT which looks correct. UGATE and LGATE are reading 0V though, which explains why the MOSFETs aren't switched on.
    To the right there is the same gate driver, marked as PU3 on the motherboard. This reads as the same as PU2 and controls the two MOSFET pairs on the right.
    These two gate drivers are controlled by a PWM regulator ISL62773, marked as PU1 on the motherboard.
    The pinout is here:
    I'm getting 5V on VDD, VDDP and VIN. 0V on ENABLE, PWROK and PGOOD. How do I know which of these last three are needed to turn on the IC?
    I also did a trace to PGOOD, it seems to be missing 5V out of this component circled in yellow. What is this component?
  • xZeroCool
    Biostar A320MH Ver 6x - Turning off on random seconds/minutes
    by xZeroCool
    Hi, I've got a Biostar A320MH Ver 6x. This motherboard basically turns off by itself even if I'm only in the BIOS Screen.
    Sometimes it will just turn on but no display, but if it POSTed it will show CMOS Fail everytime.
    The things I did to try fixing the problems with no luck.
    1. Changing CMOS Battery
    2. Reflash BIOS CHIP with latest bios file using desoldering method.
    3. Check voltages and it is just normal.
    Any ideas what the problem might be?...
    07-20-2024, 11:12 PM
  • BlackScreen_22
    Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
    by BlackScreen_22
    Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
    Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
    I had no problems connecting mosfets and capacitors,...
    08-27-2024, 12:46 PM
  • kotel studios
    Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
    by kotel studios
    Finally got time to fix this board up.
    At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
    Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
    04-22-2025, 05:08 AM
  • flerre
    Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
    by flerre
    Hi!
    Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
    No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
    So, could I safely assume all of these 3 mosfets are...
    03-13-2022, 12:14 PM
  • NanoTesting
    Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
    by NanoTesting
    I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
    With charger it turns on, fan spins but gives no image.
    Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
    Reflashed BIOS, same problem.
    Replaced both main mosfets.
    Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
    10-30-2024, 10:48 PM
