I have a laptop hard drive that I've plugged into different computers and it is not getting recognized. I'm using a usb connector/sata adapter to use it as usb storage, but "Disk Manager" is not giving me the Initialize disk option. I can scan the disk for error, I tried in Windows and Linux with same result. Is this a problem with the hard drive hardware? has anyone repair a hard drive before?
Laptop Hard Disk Not Recognized By Computer
Re: Laptop Hard Disk Not Recognized By Computer
https://smallbusiness.chron.com/run-...ntu-54071.html
first do lsusb in linux .Last edited by petehall347; 04-19-2021, 11:07 AM. -
looks like a disk not detected or detectable error. whats the capacity or size of that drive? could be an issue whereby the usb to sata adapter cannot support the capacity of the drive. try another usb to sata adapter preferably a newer one.
u can also try connecting it via esata or to the motherboard's internal sata ports. if it detects, its a problem with the usb to sata adapter. many of those adapters are problematic, typically because they cant supply enough current to the drive since usb is limited to 0.5A of current and many laptop drives need more than that to supply enough power to the drive.Comment
by DynaxSCHi,
I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
The board is generally working now, all PCIe ports are working, Windows installs normally.
However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA... -
This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...09-06-2024, 09:30 PM
This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-06-2024, 08:47 AM
by RdeveLabsTo all the members here...
Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But... -
by madura2010Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
i checked the connectivity of ribbon=good communication with hard and motherboard
changed hard disk and checked=3f0 error persist
sata power=+5v available
Then checked data capacitors=all good
Then checked data lines path connectivity to pch=all good
reflashed... - Loading...
