Laptop Hard Disk Not Recognized By Computer
  • Zentech
    • Feb 2021
    • 94
    • Usa
    I have a laptop hard drive that I've plugged into different computers and it is not getting recognized. I'm using a usb connector/sata adapter to use it as usb storage, but "Disk Manager" is not giving me the Initialize disk option. I can scan the disk for error, I tried in Windows and Linux with same result. Is this a problem with the hard drive hardware? has anyone repair a hard drive before?
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    Re: Laptop Hard Disk Not Recognized By Computer
    https://smallbusiness.chron.com/run-...ntu-54071.html
    first do lsusb in linux .
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3266
      • Singapore
      looks like a disk not detected or detectable error. whats the capacity or size of that drive? could be an issue whereby the usb to sata adapter cannot support the capacity of the drive. try another usb to sata adapter preferably a newer one.
      u can also try connecting it via esata or to the motherboard's internal sata ports. if it detects, its a problem with the usb to sata adapter. many of those adapters are problematic, typically because they cant supply enough current to the drive since usb is limited to 0.5A of current and many laptop drives need more than that to supply enough power to the drive.
      • brethin
        • Dec 2008
        • 1907
        It broke throw it away.
        • mkdj
          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
          by mkdj
          Dear all,
          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
          Here the steps I have taken to fix the laptop:
          - downloaded latest BIOS from Lenovo Website...
          10-18-2025, 03:43 AM
        • DynaxSC
          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
          by DynaxSC
          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
          The board is generally working now, all PCIe ports are working, Windows installs normally.
          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
          03-10-2025, 12:27 PM
          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
          09-06-2024, 09:30 PM
          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-06-2024, 08:47 AM
        • RdeveLabs
          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
          by RdeveLabs
          To all the members here...
          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
          05-05-2025, 04:59 AM
