New Members
Please consider donating to this site if it has helped you. We rely on these donations.
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
Apple Mac Mini A1347 Late 2014 completely dead no power
Re: Apple Mac Mini A1347 Late 2014 completely dead no power
So I kept the multimeter on the suspected inductor for about 2 minutes and I saw that the resistance reads 3.6k ohms on each side of the pins.
Now am super confused.
Any help guys
I can't quite understand it. Yes an open circuit inductor is obviously a fault, but then that same power rail has 3.3V which suggests that this buck converter is working which would mean the inductor is working - unless that 3.3V got there by some other route
I am open to any ideas. I know there are many knowledgeable individuals here. dicky96 really help me a lot. Guided me on the right track. I am still reading the pulsing voltages on all the other inductors except the one with the 3.32 volts.
I thought you said the supply rail that was going to 1.45V was pulsing on and off, but all the others were reading just a few mV? Apart from 3.3V which I think we can assume is the Standby Voltage rail
My bad. The voltage is 00.2mv then it goes to OL and then to 00.2mv and keep pulsing between those two values. On some i am getting 22.5mv and OL and keep cycling between those two values.
I was probably reading those wrong. Sorry bout that
No, probably you are reading them right but your multimeter can't read the voltage fast enough because it is auto-ranging
If it has a non-auto voltage range like 19.99VDC then select that. Now can you see what is happening. Possibly it autoranges to 1.99V by default and all the other voltage rails are higher than that so you don't get to see what is happening
Having said all that it looks like this board is stuck in a constant power on - power off cycle (apart from 3.3V standby) and as none of the voltage rails appear to be short to ground it is not obvious why. Possibly one of the buck regulators (those inductor circuits) has a faulty high value, or open circuit, current sensor resistor so it keeps thinking here is an over current situation and shutting everything down
This is where things get more difficult, but not impossible. Next thing, we need to identify the Power IC's (what are the part numbers) for each buck regulator and see if we can find a datasheet for each one
So that's the next thing you need to do. Read the IC part numbers then google for 'datasheet xxxx' where xxxx is the part number. If that does not work ask to identify the IC or for datasheets on the forum.
Thanks for your reply. What are the power IC and where are they located? I will look for the datasheet if I can identify the power IC. Is it the ones I circled red in the photo below
Those are capacitors. Let's just go back to that open circuit inductor again first. Regardless of how the 3.3V is getting on to that supply rail, you should not have an open circuit inductor. If it is actually open circuit, which your multimeter says it is (then the 3.3V is getting there by some other route) so you would see 3.3V on one side of the inductor and something else (probably 0V) on the other side. Is that what you have?
Under that black insulating plastic on the bottom right hand side of the board, is that a CMOS battery? If so, what voltage does it have?
Yes. I am getting 3.32vdc on the other side of the inductor.
Yes the CMOS battery is on the bottom right hand side of the board and it measures 3.09vdc.
Note: I removed the CMOS battery and power the board and am still reading 3.32vdc on that inductor on both sides.
thanks for helping me understand the circuit a little more. you really improve my knowledge . i really appreciate your help. It is weird that there are no schematic for this board 820-5509 anywhere. I guess that is Apple for you.
Hopefully someone here can also chime.
I'm replacing a hard drive on a Mac Mini A1347 (2014) (820-5509). I reinstalled it and got three beeps at startup.
I tried a PRAM reset, but it didn't go through the three beeps.
I removed the battery, no change.
I examined the logic board under a microscope, but I didn't see anything.
Can someone please tell me what to do or what to look for?
Thanks everyone.
Hello i have got a Mac Mini 2014 with 820-5509A motherboard it powers on but i cannot install macOS, in first part of installer it goes about 75% and reboots back again to installer
I think the bios was changed because it has a lot of flux around EFi chip
Thanks in advance
This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
This specification for the HP Stolnà poÄÃtaÄ 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolnà poÄÃtaÄ 260 G3 Mini boardview and Stolnà poÄÃtaÄ 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
