XFX RX 580 8GB GTR Black Edition 8gb OC+ - no display
  • wtracz
    • Dec 2020
    • 4
    • nor
    XFX RX 580 8GB GTR Black Edition 8gb OC+ - no display.
    No short circuits, fuses is OK. Resistance to the ground and voltage like a photos. The card graphics is after the miners.
    I have two IC flash 2x 2xfm25f02a. I reprograming external programmer both 2xfm25f02a this dump
    https://www.techpowerup.com/vgabios/...80-8192-170323
    But still no display. I tested on HDMI and DP
    Best Regards!
    https://www.badcaps.net/forum/attach...1&d=1615293625
  • RethoricalCheese
    • Mar 2013
    • 1518
    • Estonia
    Re: XFX RX 580 8GB GTR Black Edition 8gb OC+ - no display
    Does your computer POST when card is connected?
    Are all voltages present/does the GPU get warm?
    • wtracz
      • Dec 2020
      • 4
      • nor
      Probably not, the buzzer does not make any sounds.
      GPU is warm
      With other GPU card (good), PC is turns on.
      • frazerxavier
        • Mar 2021
        • 42
        • India
        GPU is warm
        Did you manage to fix the card? I have a similar issue too with an XFX RX 580 8GB.
        • foshland
          • Jan 2017
          • 122
          • Spain
          Hi, first clean it all with alcohol and a brush, take your time, slow but make it shiny, i have repaired 2 cards just with that. Then the 0.86V looks strange, if someone knows if it is correct, please post it.
          Assure 78M05 is giving you 5 volts
          • DrasticRepairs
            • May 2021
            • 23
            Have you checked resistance of 3.3V and perstb (pcie pin A11)?
            Edit: Also try all display outputs and see if it shows up in device manager as a secondary card. Sometimes bad VRAM will only let the card display from one output.
            • frazerxavier
              • Mar 2021
              • 42
              • India
              It does not get detected as a secondary card. I will check the resistance on PCIE pin A11 in the evening today and post the findings.
              • frazerxavier
                • Mar 2021
                • 42
                • India
                I will check the output on 78M05 and post the result in the evening today. I cleaned the whole surface with alcohol but its the same.
                • Beton
                  • Dec 2021
                  • 10
                  • Hungary
                  Isn't 0.6ohm on the GPU too low? It's basically the resistance of the probes. I thought that only the newest GPUs have 0 ohm resistance.
                  • Toricaco
                    • Dec 2019
                    • 14
                    • Estados Unidos
                    hi guys, could somebody help me to identify the component marked in red on this card
                    • mkiani
                      • Aug 2022
                      • Iran
                      I am not sure but I think it is the following IC (LMP8640/-Q1/HV Precision High Voltage Current Sense Amplifier):
                      https://cdn.badcaps-static.com/pdfs/...76ec408034.pdf
                      Check it out.
                      • Eduard Al
                        • Aug 2022
                        • 29
                        • Romania
                        If the card is not detected in device manager and you have all voltages, try to change U100 , is this a logic ic marked usualy VE
                        • tucker01max
                          • Jun 2022
                          • Algeria
                          Hello i have RX 580 Sapphire Nitro +
                          and instead of U100 i have u4513 and it looks blown any idea how to get a replacement
                          its a 74LVC1G08 with 5 legs it appears on the pictures as "VE"
                          and what can cause that to blow
                            • 31017
                            you can buy single gate logic from all the main suppliers
