Another Tagan, this time with failed Panasonic...
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Another Tagan, this time with failed Panasonic...
    Originally posted by i4004
    are you sure?
    just a few days ago you were asking what exactly +5vstby circuit with a chip is:
    https://www.badcaps.net/forum/showpo...51&postcount=1
    and a while back you were not certian about 2 tr. design when you saw one
    https://www.badcaps.net/forum/showpo...5&postcount=15
    <wink>
    And the award goes to...
    i4004, yes! It is true! You are the most pretentious douche bag in the world! (quite frankly i am sick of it as are other members...)
    Congrats. I know what a two transistor 5vsb circuit is, that was the point of the thread with the yuelin (quite a while ago I may add) and what threw me off with the solytech is that it is almost exactly the same in every way to the one wolf tested. I also know how to use this cool tool called "google" that can look up part numbers for things like, transistors, etc... Thats also a good way to identify them.
    Sorry, I had to take you off ignore just to see your reply...hehe
    <wink>
    • i4004
      • Oct 2006
      • 2029
      hell man, either ignore (and make yourself ignoramous baboon) or don't.
      don't be in the middle.
      if you've found a datasheet (like you did) and still didn't know, then one wonders if you like electronics enough to reasearch it further.
      wasn't it on the wall, smps chip connected to +5vstby primary?
      was it an elephant, or smps regulator?
      btw. these two last posts....i'm just teasing you because i don't like the word "ignore" in any way or form.
      that's how i tease, by linking your posts.
      <wink>
      still, do watch out for them topswitches....hehe...
      edit/
      yep, there we have bonez (who cannot grasp most simple electroncs terminology) and toasty, who's blowing up other people's psus with his advices.
      and now we have you: you have 2 psus of same sort and can't dismantle one to see whats wrong with other one(talking about that 700w delta).
      surely the bunch.
      oups, there i go teasing again... i'm sorry...
      anyway, ignore away!
      i'll still comment your posts.
      • robert
        • Jan 2008
        • 69
        Now for the PSU again, i decided to look around my parts box and have a try with whats around.
        5V: 2* 3300/10V 10mm -> 4700/6.3V 12.5mm Rubycon XYF
        12v: 2200/16V 10mm -> 2200/25V 12.5mm Chemicon LXF
        3.3V Input: 2200/16V 10mm -> 1500/16V 10mm Rubycon MBZ
        3.3V output 2200/10V 10mm -> 2* 1500/10V Sanyo WG 8mm parallel
        3.3V output: 2200/10V 10mm -> 1500/10V Sanyo WG 8mm
        5V Stby: 2* 1000/10V 8mm -> 2* 1000/10V Panasonic FC
        Primary: 2* 470/200V 22mm -> 2* 1000/200V 25mm Hitachi HP3
        PFC: 22/400V 18mm -> 68/400V 18mm Chemicon KMX
        Should do it, hopefully.
        Didnt get around testing yet, ill post when it runs.
        Oh by the way, anyone in germany interested in a few 1500u/10V Sanyo WG 8x20mm?
        I happened to get across a large amount of these, still packaged in bags of 200.
        • i4004
          • Oct 2006
          • 2029
          why germany only?
          prices simillar to these
          http://tinyurl.com/ybhogba
          i would be interested, but i would pay you(via paypal) after receiving and checking them...offcourse, i would pay for shipping (to croatia) too, etc.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Watch out raising the uf in the PFC circuit, those are usually their values for a very good reason. Also watch out using Ultra-LESR caps like Rubycon MBZ in a power supply, this can introduce more ripple to the circuit. Of coarse, i4004 doesn't know this that is why he didn't comment on that. (BTW i think pcbonez is the one that posted about that not to long ago...hmmm)
            • robert
              • Jan 2008
              • 69
              #26
              On the place the MBZ and WG are, they cant do much to the voltage regulation loop.
              These are used on the +3.3V Stepdown, which is powered off the +5V, the ~3uH filter inductor in between isolates these capacitors from the +5V line HF-wise.
              The lower ESR here is quite useful, since 3.3V ripple is quite bad even when new and the 3.3v input cap doesnt last long (even though they used a 16V unit on 5v...).
              Also, trouble with lower ESR does happen sometimes, but not often. Im gonna see.
              For the PFC:
              The 22u (now 68u) is in parallel with the main filter caps ( previously 235u, now 500u).
              This should not be much of a trouble, especially since the higher wattage units use the same PFC board, but up to 600u of filter cap on the main board.
              BTW: Thanks Topower for the 3842 based stby PSU. The caps in there were SO done (ESR over range, ie 20Ohms), the 2-transistor-crap would have killed the mainboard instantly, this thing surprisingly still kept the 5vstby stable enough to power up.
              However, this is the only thing i will ever thank Topower for.
              • i4004
                • Oct 2006
                • 2029
                #27
                you have the load and scope to check the ripple?
                • robert
                  • Jan 2008
                  • 69
                  #28
                  Active load: Not in this power range, but a good stash of power resistors that can help.
                  If not, the good old steel fence wire wound around a brick resistor works, too.
                  Scope: Which one of the 7 or 8 (yes, i dont actually know how many scopes i have at the moment... I kinda collect (mostly HP) test equipment) should i use?
                  • i4004
                    • Oct 2006
                    • 2029
                    #29
                    as long as it's the fence wire, scope doesn't matter!
                    <wink>
                    • hardwareguy
                      • Jun 2006
                      • 405
                      The primaries failed either due to heat (85C only lasts so long in PCs!) or the bodged APFC circuit.
                      I 2nd the Fortron recommendation! They had a couple models that weren't too great but most have been rock solid. The bad caps mar what was a good design on some, but for $5 this is remedied.
                      As for Seasonic....I love them! My M12 even has UCC caps inside....and I didn't put them there. \
                      Seasonic makes a rock solid 80+ certified 380W, but at $60-70 USD its not cheap.
                      • ahmedtou
                        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                        by ahmedtou
                        help me please
                        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                        I will share all the details with you, including the disc information.
                        Code:
                        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                        Current Profile: BD-R
                        Disc Information:
                        Status: Empty
                        State of Last Session: Empty
                        Erasable: No
                        Free Sectors: 12,219,392
                        Free Space: 25,025,314,816 bytes
                        Free Time: 2715:27:17 (MM:SS:FF)
                        Next
                        08-27-2025, 08:49 AM
                      • Andre Gilbert
                        by Andre Gilbert
                        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                        11-20-2024, 08:52 PM
                      • titomno2
                        Gaming Laptop Zephyrus S17 TFT not detected every time !
                        by titomno2
                        Hi guys,
                        I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                        So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                        On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                        Then the screen won't work for a long period of time.
                        If I wait 1 or 2 hours it work again most of the time.
                        When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                        01-19-2025, 08:27 AM
                      • novak2
                        Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
                        by novak2
                        Hello there,
                        I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
                        The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
                        From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
                        Thanks in advance.
                        09-25-2020, 02:34 PM
                      • flat-earther
                        Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                        by flat-earther
                        I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                        To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                        I have opened the camera and I think there is enough room to add something inside to accomplish this:
                        The camera is powered by a 3.7V nominal single cell lithium ion battery.
                        So I need to connect another battery in...
                        06-08-2025, 02:00 AM
