Asrock FM2 mainboard mosfet info
  • 386SX
    • May 2020
    • Italy
    I've an Asrock FM2A55 DGS mainboard and got it untested and as usual don't boot up (fan ran, chipset get warm but no beeps no video output). After every usual no-posting solutions (cpus, ram, pcb cleaning, etc), I was expecting it to be broken but only lately I've seen a smd component with the package broken on the mainboard, the Q38 marked one. Thanks to another forum user info, what I look for should be an AP2309GN p-mosfet in the SOT23 package. Considering that specific one seems not easy to be found on the usuals online europe stores, would you suggest some compatible p-mosfet model? For example it seems the AO3401 is easier to find and having similar values but not exactly. Which values do I have to consider for looking a compatible one while others I may not consider?
  • Jane
    How do you test MOSFET in laptops ?
    by Jane
    I tried to use this method:
    Testing an N-channel MOSFET:
    Step 1: Discharge the Gate (turn off the MOSFET)
    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
    Step 2: Charge the Gate (turn on the MOSFET)
    Now, place the red probe on the Gate (G) and the black probe on the
    09-27-2024, 03:31 AM
  • Nooy
    VGA MOSfet permanently shorted and loss of MOSfet pad
    by Nooy
    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
    02-14-2024, 02:26 AM
  • stavi
    Asrock 775V88+ mosfet identify
    by stavi
    I want to identify a mosfet. Unfortunately, I couldn't find the asrock 775v88+ schematic.
    Does anyone know what this mosfet could be? It is between the agp port and the 1st pci slot. Q14 is his number.
    Thanks for the help...
    09-08-2022, 07:49 AM
  • AppleLover123
    Asus X712EA 3 volts after the first mosfet
    by AppleLover123
    Hey guys,
    i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
    I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
    Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
    I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
    Now i thought something...
    12-15-2024, 07:49 AM
  • MicroSMD Lab
    by MicroSMD Lab
    I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
    01-10-2024, 06:36 AM
