Biostar M7VIG 400 with Suspect caps, need help.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Biostar M7VIG 400 with Suspect caps, need help.
    sounds like its time for a long run ups and folding at home.team 49813 to be exact.
    and look at this.
    https://www.badcaps.net/forum/showth...t=ups+external
    • c_hegge
      • Sep 2009
      • 5219
      Finally. Got a 48hr run without a power black out or windows updates. Looks like its fixed It's powering this post.
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
