biostar u8068 cap layout help
  • yonu
    • Nov 2007
    • 138
    hey I need some help guys i picked up a biostar u8068 ver 1.1 from a electronic shop today to replace a board in a project I am working on and they siad they were removing caps from it since it was so old the problem I am having is none of the solder pads look like they have been messed with I can provide pics if that helps I just don't want to toss a cpu in it and fire it up if any have been removed.
    Thanks,
    yonu
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: biostar u8068 cap layout help
    here:
    an overview of your board:
    but that is small, i found a bigger one but part is obstructed by the cpu fan:
    another view:
    go from there.
    sigpic
    (Insert witty quote here)
    • yonu
      • Nov 2007
      • 138
      Great thinks that helps now question the caps that were removed should be 16v 2200f the closest I have on hand is 16v and 2700f should I be ok with those or do I need to find the exact ones?
      Thanks,
      yonu
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        2700uf will be fine, if anything, a little better.
        What brand and series? Make sure they are low-esr.
        • yonu
          • Nov 2007
          • 138
          they are just some nonname ones i had laying around ok it replaced the 2 caps that were removed but i get nothing when putting power to the board so i stuck my post test card in a pci slot and according to it it has 3.3v but nothing else when i hit the power button nothing no other rails come on now post codes nothing I know the psu is good
          any thoughts,
          yonu
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            No-name caps never good. Just use good caps from the start.
            • yonu
              • Nov 2007
              • 138
              hey like i said I had them, guess I will go see what I can find tomorrow no real electronic shops around here
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                Does the southbridge get hot while the psu is plugged in? If it does, your motherboard is fried from some cheap psu with a high 5vsb.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  2700uF is fine.
                  ->> But that's NOT what's important.
                  What is the ESR and Ripple on the old caps.
                  What is the ESR and Ripple on the new caps.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • yonu
                    • Nov 2007
                    • 138
                    not sure will check on the southbridge
                    • yonu
                      • Nov 2007
                      • 138
                      well i ran and checked the southbridge it doesn't get hot but it does get warm so i would take that as they sold me a board with a bad southbridge
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        its supposed to get warm, but not hot. there is a reason why southbridge coolers exist. order some caps and give it a shot.
                        sigpic
                        • yonu
                          • Nov 2007
                          • 138
                          ok I will give it a try
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            good luck!
                            sigpic
                            • yonu
                              • Nov 2007
                              • 138
                              well I got the caps replaced with good ones and is doing the samething so I am just going to take it as a bad board and start shopping again
                              Thanks,
                              yonu
                              PS. anyone got a socket 478 matx for sale cheap lol
                              • ksysa
                                Board Layout of iPad Pro 10.5 (Model : A1709)
                                by ksysa
                                Good day, everyone! Can anyone please share a board layout (complete with components, test points, etc.) of iPad Pro 10.5 (Model : A1709)? There is already a schematic diagram of iPad Pro 10.5 here but somehow it lacks the complete board layout. I need to know where the specific Test Points (TP) are on the motherboard. I hope someone can help me.
                                07-16-2025, 02:36 AM
                              • selectivetao
                                Request for Boardview/Schematic - Biostar B660-T Silver Motherboard
                                by selectivetao
                                Hello fellows,
                                I am putting a feeler out for a schematic (or ideally boardview) for the Biostar B660-T Silver motherboard.
                                I had let my guard down and decided to trust the Biostar supplied Windows based BIOS flash tool, only to find that the system would not POST upon restart.
                                no problem I thought - I would just flash using my trusty CH341 and be on my merry way.
                                Upon inspecting the board and locating its Winbond NOR, I found it in a rather precarious spot nestled between the RAM slots and PCIe slot and right next to a rather meltable-looking...
                                12-13-2024, 09:37 PM
                                Biostar GeForce 6100 AM2 (CRU51-M2) Schematic
                                Biostar GeForce 6100 AM2 Ver. 1.x is a motherboard based on the Nvidia nForce 410 (GeForce 6100) chipset....
                                10-31-2024, 02:29 PM
                              • Adrean88
                                Biostar TA870+ ver5.2 schematics or boardview
                                by Adrean88
                                Hallo guys
                                can anyone have schematics or boardview for Biostar TA870+ ?
                                I want to diagnose the problem, all voltage seems to be present, but still give me D0 code when I put diagnostic card in there
                                thanks
                                10-24-2025, 09:11 PM
                              • aatech1
                                Request: Biostar A320MH Ver. 6.7 Boardview (for OpenBoardView)
                                by aatech1
                                I’m looking for the boardview file for the Biostar A320MH Ver. 6.7 motherboard.
                                Preferred format: OpenBoardView-compatible (.fz, .cad, or .brd).
                                I already saw that some revisions (like Ver. 6.0) are around, but I specifically need Ver. 6.7 if possible.
                                Thanks in advance to anyone who can share or guide me to it!
                                08-31-2025, 06:26 AM
