Ecs P45sa
  • synicalsoldier
    • Jun 2005
    • 5
    Ecs P45sa
    Hi, I own a ECS P45SA which died and also killed my cpu.
    I recapped it with the caps I bought from this site. The only difference between the old caps and the new caps is the brand (old OST - new Rubycon) and some name on the caps (old RLX - new MBZ).
    The cpu fan spins and stops and that is all that happens, same as before I had replaced the caps and the cpu.
    I am wondering if MBZ may be the reason why? I don't know anything about these names, but would this be why it still won't power up? Should I have gotton caps with RLX?
    or would it be the VRMs?
    Thanks,
    John
  • Fatal0E
    • Jan 2004
    • 252
    Re: Ecs P45sa
    Probably the VRM's are shot
    • synicalsoldier
      • Jun 2005
      • 5
      Re: Ecs P45sa
      thanks, do you know how I might go about replacing them?
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Re: Ecs P45sa
        RLX are OST crap. they are guaranteed to fail. MBZ are one of the best rubycon caps and there is no issue with replacing RLX with another brand of caps.
        you have other probs, yeah it might be VRMs. your board needs more work than just replacing caps.
        i PM Topcat who supplied you the caps to assist further.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Re: Ecs P45sa
          Agreed. Check the VRM FET's for shorts, thats the starting place. If the FET's read OK with a tester, then likely the regulator itself is cooked. If the FET's are shorted, they arent that difficult to replace, but pray that nothing else further up the line is cooked too.
          Another example of not waiting to recap a board.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            Re: Ecs P45sa
            check your voltages also before you nuke more components.
            • synicalsoldier
              • Jun 2005
              • 5
              Re: Ecs P45sa
              Hi, thank you all for your answers.
              I have another question.
              When I saudered the new caps on, I only saudered them at the bottom of the board, I did not melt the sauder into the holes where the caps metal legs go. Could you please tell me if this may be why its not working?
              • Chris1992
                • Apr 2005
                • 561
                Re: Ecs P45sa
                Probably not, unless you damaged the foil in the holes. If you melt the solder so it's contacting the bottom of the board, then the foil in the holes will make an electrical connection through the board. And is this a s423 or s478 or lga775 board?
                The great capacitor showdown!
                • synicalsoldier
                  • Jun 2005
                  • 5
                  Re: Ecs P45sa
                  its a 478pin.
                    by momaka
                    03-12-2025, 03:42 PM
                  • eryjus
                    by eryjus
                    05-10-2023, 11:21 AM
                  • Paxman_Swede
                    by Paxman_Swede
                    Hello!
                    01-14-2025, 09:51 AM
                  • captain150
                    by captain150
                    03-16-2025, 07:34 PM
                  • Foetuss
                    Gigabyte GA-6OXT :: caps question
                    by Foetuss
                    Good evening
                    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                    But I was also suprised about the bigger boys, which are 330µF 25V.
                    Could it be they used 25V caps because they were cheaper / available at that time?...
                    02-11-2025, 12:22 PM
