Soyo SY-6VBA133 - no POST
  • Dan81
    SNES-powered
    • Oct 2013
    • 1865
    Got one of the oldies here, and it finally bit the dust.
    Originally came with Wendell caps and would not power on until I replaced all the bigger Wendell caps with 1500uF Panasonic FL.
    It will now power on fine, but will not POST - on power on I just get a continuous rapid clicking from the speaker, regardless whether I have RAM inserted or not. CPU is a P3 500MHz Katmai, but I have tried a 550 Katmai and a 650 Coppermine model as well.
    Any help is appreciated, as I would love to get this board working and replace the Acorp 6VIA81P I currently have, as Soyo makes much better boards than Acorp.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
  • cpt.charlie
    • Sep 2013
    • 270
    • Spain
    Re: Soyo SY-6VBA133 - no POST
    Maybe more caps are failing without visual signs of damage, clicking from the speaker could be some kind of reset behavior.
    • Dan81
      SNES-powered
      • Oct 2013
      • 1865
      I was thinking of reset too, could the small caps (22uF 25V to 100uF) cause this issue?
      Main rig:
      Gigabyte B75M-D3H
      16GB DDR3-1600
      Delux MG760 case
      • cpt.charlie
        • Sep 2013
        • 270
        • Spain
        Small caps tend to have a shorter life.
          master hoarder
          • May 2008
          • 12170
          Could we see some pictures of your board and work? If it worked before (or at least POSTed) and not now, then it may help to trace back what you did. Not necessarily implying that your broken it, as there could have been an issue with the board beforehand, waiting for someone to touch the "right spot" on the motherboard to break it.
          So the more info and pictures we have, the better.
          • Dan81
            SNES-powered
            • Oct 2013
            • 1865
            Check the best cheap/free scores thread. I already scrapped it in favor of a 6BA+IV model that also has a HPT366 RAID controller, as well as the more versatile 440BX chipset instead of VIA 693.
            Wasn't such a big loss. I'm holding off recapping the 6BA+IV until I can get a proper wattage soldering iron that is more powerful (at least 60-100W) because of the huge power planes around the CPU. A low wattage iron was the 6VBA133's demise - because it was 40W, I struggled so hard to get the caps out that I destroyed the internal layers of the board and also somehow I managed to fuse the cap holes with the whole plane they were on, shorting out the VRM.
            All in all, it wasn't worth beating a dead horse - I already took all jumpers and BIOS chip, and scrapped it in favor of a 6BA+IV I just got from the same dude that sold me the 6VBA133. This one just had some scratched traces, nothing a cutter and a few dabs of solder couldn't fix.
            Main rig:
            Gigabyte B75M-D3H
            16GB DDR3-1600
            Delux MG760 case
              master hoarder
              • May 2008
              • 12170
              Yeah, I saw that. Just wasn't sure if you kept it around and still wanted to take a stab at fixing it.
              Oh well...
              R.I.P. SY-6VBA133
              Yup, too weak an iron will do that.
              Though if it was a well-built 40W iron with a very thick copper tip (my dad has one like that from the late 70's / early 80's and it's tank), it could work OK. It's mostly all about heat transfer. If you have low power, you can substitute that with large thermal mass and vice versa. But if you have poor heat transfer (thin tip or tip made of cheaper materials), nothing will save you.
              That's why with hot air, you need so many Watts to heat something to remove it - because air has pretty poor heat transfer. But then its advantage is that you can remove things without any physical contact from the tool.
              • Dan81
                SNES-powered
                • Oct 2013
                • 1865
                It is one of those Radioshack style chinese crap irons. I had a 60W one with a really thick tip but that one died. (wouldn't heat anymore - mica based, like the 40Ws I have are made - ceramic stuff is way too expensive here)
                I was thinking of asking one of my friends who runs a repair shop if I can use his solderi g station (it's a Pro'sKit station) as it's temperature controlled and I might have better results.
                Main rig:
                Gigabyte B75M-D3H
                16GB DDR3-1600
                Delux MG760 case
                  master hoarder
                  • May 2008
                  • 12170
                  They probably used too thin NiChrome wire on it, so it ran too hot for its own good.
                  That said, you can buy cheap NiChrome wire online and rewind it. Maybe even make it more powerful, if you like? Or dual-power with dual windings?
                  And instead of temperature control, you can put a switch to toggle between full power and half power (for half power, just put a single diode in series with the live - this should be about enough to keep the iron up to temperature once it's hot enough and not over-burn the tip as fast.)
                  Only if it's a good quality station.
                  Just because it's temperature controlled doesn't really mean anything. The cheapo Hakko 936 clones that use 900M tips are about as sad as any other cheaply-made wall / constant power iron. The iron that came with my KADA 951D+ is pathetic. Last time I used it was probably 2 years ago. It just sits down in the garage uselessly. I only keep that station for the hot air (and even that rarely sees a use anymore, but at least it's a working hot air station. The temp-controlled iron, on the other hand... ).
                  • Dan81
                    SNES-powered
                    • Oct 2013
                    • 1865
                    I ended up getting a Kemot soldering iron. Ceramic resistor that heats up, and tip is a strong one that doesn't eat itself lol.
                    Recapped the 6BA+IV w/ Panny FJS (from an dead NEC machine, board had bad SuperIO chip) and Rubycon MBZ from same board, along with two Sanyo WF in the corner of the board. POST'd just fine, though it's picky about what RAM sticks it eats.
                    Main rig:
                    Gigabyte B75M-D3H
                    16GB DDR3-1600
                    Delux MG760 case
                    • angel35
                      Acorp 6VIA81P no post
                      by angel35
                      Hello I have an old Motherboard
                      Type: Acorp 6VIA81P Ver. 1.6
                      It is works...and slowly died... freezing 1-2 times...and after that not windows starting...now totally not booting
                      PCI post card 7 segment --,-- (1 times appear 06,05 but never more)
                      Leds: IRDY, Frame, Reset not flash
                      So looks like it is hardware fault..
                      I checked some voltage, but looks like good at FETs
                      Capacitors ok, not damaged (but not checked the values)
                      SD ram 256MB tested in other board ok
                      Pentium2 400 slot1 tested ok
                      10-30-2022, 04:06 AM
                    • angel35
                      Acorp VIA81P schematic
                      by angel35
                      I request Schematic
                      10-30-2022, 04:03 AM
                    • silencerar
                      Soyo SY-7VBA133 Won't react to power on. Could it be this capacitor?
                      by silencerar
                      Hi! I have an old SY-7VBA133 that I can't manage to turn on. The power supply works and the processor does as well.
                      According to the manual it looks like it should have a 5v indicator led, which doesn't turn on (I really don't know where it's located either)
                      I've noticed that it has a capacitor next to the power supply connector that is slightly bulged. Before I try to replace it, do you think it could be the cause for this motherboard not turning on?
                      There are 3 capacitors, it's the one in the middle.
                      I've uploaded a picture of it here...
                      05-10-2023, 04:33 PM
                    • rattlesnake
                      Soyo SY-7VBA133U recap
                      by rattlesnake
                      Hi guys,
                      I'm going to recap this baby. I found it dumped in the street years ago, and now it's time has come. I remember having tested it and it posted back then.
                      Original caps are bulged and look nasty. All are SACON
                      11 x 1000uF 10v
                      12 x 1500uF 10v
                      1 x 470uF 16v
                      11 x 22uF 25v
                      1 x 10uF 25v
                      The smaller ones look fine. Should I replace them too?
                      I read on another forum that I could replace the 1500uF caps with 2200uF caps. Is that so?
                      The thing is I could get Sanyo 2200uF or Capxon 1500uF (or Jackon 1500uF)....
                      04-10-2022, 06:47 AM
                    • gintama
                      Soyo Class Action Suit (for bad mobo caps)
                      by gintama
                      Just came across this page this morning, while downloading some drivers from soyo's site. They have a small image on the homepage:
                      The dates are at the end of the summary, and it's pretty late in the game. Not that it makes much difference for me anyway, since I'm not in the US. You still have time to make a claim though.
                      Text is reproduced here for ease of perusal.
                      From Soyo Group Inc:
                      SOYO is proud of its tradition of innovation and quality. However, if we ever...
                      10-03-2007, 11:46 AM
