Hello I have an old Motherboard
Type: Acorp 6VIA81P Ver. 1.6
It is works...and slowly died... freezing 1-2 times...and after that not windows starting...now totally not booting
PCI post card 7 segment --,-- (1 times appear 06,05 but never more)
Leds: IRDY, Frame, Reset not flash
So looks like it is hardware fault..
I checked some voltage, but looks like good at FETs
Capacitors ok, not damaged (but not checked the values)
SD ram 256MB tested in other board ok
Pentium2 400 slot1 tested ok
CPU hot
Memory (board upside hot, AGP side cold)
Nortbridge slowly warm
Southbridge cold or very slow warm
South FAN connector RPM sensing voltage is 0 (other FAN conn RPM sensing 5V) Q14 (2Ay) changed, because it was shorted burnt.
So i request help what should be check.
CPU hot
