Biostar Geforce 6100-M9
  • gobbler
    • Jun 2009
    • 55
    Hi
    Bought this Biostar Geforce 6100-M9 motherboard cheap, owner said will encounter hang in windows XP every time after using 10-15 mins. I did try installing windows XP, true enough, I encountered same problem.
    No bloated caps.
    VRM :-UCC KZG series 3300mF 6.3V (x5) (esr reading 0.01)
    UCC KZG 1500uF 16V (x3) (near MOSFET) (esr reading 0.00 or 0.01)
    OST RLP series 1000uF 6.3V (x12) (near memory slots, north bridge) (esr reading 0.02 or 0.05)
    OST RLG series 100uF 16V (x17) (all over the motherboard)
    If I were to try recapping, any recommendation which range I should start with or any guys have experience regular hang in windows XP?
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Biostar Geforce 6100-M9
    Sounds more like a overheating issue (especially if XP works solid in the first 10-15 minutes). Reason I don't think it's the capacitors is because their ESR actually gets lower as their internal temperature rises.
    Check to see if the Northbridge/Southbridge are not overheating and make sure that their heatsinks have proper thermal compound. Also check the VRM/FETs for overheating issues.
    If there are no heat issues, then it could be the Ost caps going bad. Before you spend money on new caps, however, it's probably better to wait for a few more opinions here. Maybe there could be something else wrong.
    • yanz
      • Nov 2004
      • 910
      did u really succesfully installed win xp on it? what about doing memtest+ moren than 15mnt.. will the problem occured?
      days are so short when you actually do something..
      • Maxxarcade
        • Jul 2006
        • 973
        I've worked on several of these. Usually the 1000uf caps are bad. On the last couple I fixed, the ones over by the RAM were bulging, and also the cluster of 3 near the opposite corner. I replaced all of them, and a few of the 100uf for safe measure.
        The south bridge also gets pretty warm. You might want to put fresh thermal grease on it.
        Also clean/re-seat the RAM and run MemTest86.
        • gobbler
          • Jun 2009
          • 55
          Hi guys,
          There is one feedback I need to add from the previous owner of the motherboard. "Problem: Works ok for first 5-15mins, after that it 'freezes' - still power on but no display, mouse red led turns off, etc. Tried restarting but can't work. Have to wait for ~1hr to be able to on, and the cycle repeats itself. Probably the chipset is gone case...
          momaka,
          Your suggestion did help improve the situation. The north bridge has a heat sink only while the south bridge has no heat sink at all. So I apply fresh thermal grease on north bridge. Well, it did run beyond 15 mins and I tested it till 2 hrs without any problem. So, my next test was to run Prime95 and I managed to monitor it till 10 hrs without any problem. Then, I left it to run overnight in my air-conditioned room. In the morning, the motherboard did hang with no display. So I powered it off and tried turning on using the on button switch. Everything seemed to be not working, the cpu fan not spinning. There wasn't any power on my POST card too. It seemed dead. I tried several times after 2hrs, 4hrs and even 6hrs later, same cpu fan not spinning.
          Weird thing is that after more than 24hrs later, I tried power it up again, it works this time and has display on the monitor.
          yanz,
          I did managed to install windows xp. Haven't tried memtest yet.
          Maxxarcade,
          I do not see any bulging caps and ESR readings are pretty decent so far.
          For my case, do you think I need to replace the 1000uF caps or I should try install the north bridge with heat sink with fan and install the south bridge with heat sink?
          Any suggestion what is the next course of action? Thanks.
          • Maxxarcade
            • Jul 2006
            • 973
            Sounds like you may indeed have a thermal problem. It could be either the chips or the solder. You can try adding a heatsink to the south bridge and see if it acts different.
            I'm wondering if the north or south bridge got hot enough to fatigue the solder, kind of like what happens with the Xbox 360's.
            Your ESR readings may be better in-circuit because some caps are usually in parallel. If they are not bulging, they might still have some life left in them, but I usually change them anyway. I'd start with the heatsink though.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              After applying new thermal compound to the Northbridge, how hot does the heatsink get? If it feels hot to the touch, try adding a fan on it and see if it helps. Also, see if the Southbridge gets hot as well. Add a heatsink to it if it does, like Maxxarcade suggested.
              I was thinking the same thing. Hope it's only a heat issue and not a cold solder joint.
              • gobbler
                • Jun 2009
                • 55
                Now things are getting complicated. North bridge changed to a heat sink with fan while the south bridge installed with a heat sink. Both with new thermal compound applied. Sometimes I got hung in bios boot up, sometimes during windows xp boot up screen. Even if I managed to get into windows xp screen, once I run the Prime95, I can never get beyond 12 mins. Well, once inside windows xp, the hang will either be screen freeze or screen becomes blank. Sometimes the PS/2 optical mouse does not have power.
                One thing I noticed quite consistent, whenever it hang, I powered it off and tried to on again, cannot power it up. In order to power it up again, I need to set the PSU on/off switch to off setting and try again around 10-15mins later. If I leave the PSU on/off switch to on setting, I can never power it up again. I am quite puzzled by this.
                Are the OST caps giving me this problem?
                • Newbie2
                  • Sep 2005
                  • 885
                  I doubt that this is just a capacitor problem, you did test a few of the OST capacitors and they were fine.
                  My gaming PC:
                  AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                  ASUS M4A77TD AMD 770 AM3 Motherboard
                  PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                  G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                  TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                  WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                  ASUS Xonar DG 5.1 Channel PCI sound card
                  Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                  Antec Three Hundred Mid-Tower Case
                  Microsoft Windows 10 Pro 64-bit
                  Microsoft Windows 7 Ultimate SP1 64-bit
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5038
                    • New Zealand
                    What kind of PSU are you running?
                    Did you try updating the BIOS?
                    -David VanHorn
                    • gobbler
                      • Jun 2009
                      • 55
                      Newbie2,
                      I only did in circuit esr measurement, 10 caps OST RLP series 1000uF 6.3V have reading of 0.02 while 2 caps have reading of 0.05.
                      Agent24,
                      I am using Verudium PowerXT PSU. I also tested with Silverstone SST-ST400 PSU, same symtom. Once I got hold of the motherboard, I flashed the bios to latest version.
                      • Newbie2
                        • Sep 2005
                        • 885
                        I suggest checking for any damaged traces on the motherboard, test the OST capacitors out of circuit.
                        My gaming PC:
                        • gobbler
                          • Jun 2009
                          • 55
                          i do not see any sign of damaged traces, let me order some 1000uF 6.3V caps to standby when i test the OST caps out of circuit. in the meantime, MIA awhile ..
                          • gobbler
                            • Jun 2009
                            • 55
                            guys,
                            if currently the motherboard is using electrolytic caps, can i replace it with aluminium solid caps?
                            • Newbie2
                              • Sep 2005
                              • 885
                              guys,
                              You can replace aluminum electrolytic capacitors with polymer capacitors. A general rule here regarding polymer capacitors is to use around half the capacitance of the original electrolytic capacitor when installing a polymer capacitor in its place. For example, if replacing a 1000uf electrolytic capacitor, a 470uf polymer capacitor is used.
                              Polymer capacitors are more expensive than electrolytic capacitors, and on a motherboard if you wanted to use them in my opinion they would only be required in the CPU VRM area, where caps get stressed the most on the motherboard.
                              My gaming PC:
                              • gobbler
                                • Jun 2009
                                • 55
                                guys,
                                off track a bit, i got a MSI motherboard, it has 470uF 6.3V (3 pcs) and 470uF 10V (1 pc) both G-LUXON brand. if i were to change the caps, can i standardise them to 470uF 10V?
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  Going a step higher with the voltage ratings is okay. Going a step down is not recommended, though (unless you actually measure the voltage with a DMM to determine if a lower voltage cap will work).
                                  So to answer your question, yes 470uF 10v caps should work just fine to replace the 6.3v caps.
                                  • gobbler
                                    • Jun 2009
                                    • 55
                                    guys,
                                    i remembered posting on another thread and a senior member mentioned if doing recaps, must change the same series for all e.g. if the motherboard has a 3300uF 6.3V bloated cap, must change all the caps with 3300uF 6.3V. Does this apply to the VRM area caps only, say if I got 12 pcs 470uF 6.3V all over the motherboard, only 1 bloated cap, change 1 or 12?
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3112
                                      You should replace all the caps if one is bad, that usually means the others are bad and aren't showing it, or they will go bad.
                                      • gobbler
                                        • Jun 2009
                                        • 55
                                        ok, my stocks for the Sanyo 1000uF 6.3V caps arrived and spent a couple of hours removing the OST caps and recapped with those Sanyo. but the problem still there after testing.
                                        if i used on board graphic, display will turn off after 3-4mins. if i used pci-x graphic card, it will hang during POST or in bios if i tried to change some setting.
                                          NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                                          The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                                          10-02-2024, 08:52 AM
                                          Biostar GeForce 6100 AM2 (CRU51-M2) Schematic
                                          Biostar GeForce 6100 AM2 Ver. 1.x is a motherboard based on the Nvidia nForce 410 (GeForce 6100) chipset....
                                          10-31-2024, 02:29 PM
                                          NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                                          The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                                          10-02-2024, 07:51 AM
                                          NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                                          The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                                          10-01-2024, 01:54 PM
                                          NVIDIA GeForce RTX 4080 (RTX4080) Schematic & Board View
                                          The GeForce RTX 4080 is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2022. Built on the 5 nm process, and based on the AD103 graphics processor, in its AD103-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 4080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The AD103 graphics processor is a large chip with a die area of 379 mm²...
                                          10-02-2024, 08:57 AM
