ga-78lmt-usb3 rev 6.0 no display
  • shouri
    • Jun 2016
    • 7
    • malaysia
    Hello friends,
    i got one motherboard like above that suddenly no display, can on and no auto off. i need to flash the bios but cant find it anywhere. can someone help me find this bios? or can backup bios be replace on main bios?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: ga-78lmt-usb3 rev 6.0 no display
    Use the BIOS downloaded from the manufacturer's website.
    • shouri
      • Jun 2016
      • 7
      • malaysia
      My flasher cannot flash bios with f2 file format, i need bin file format. I already search the file, all file i find only refer to gigabyte site. Can anyone help me donor the bin file on working motherboard or link for this bios? tq
      • piernov
        • Jan 2016
        • 4439
        • France
        This is the raw BIOS image, "bin" format if you want… You can flash it directly on the BIOS chip.
        • shouri
          • Jun 2016
          • 7
          • malaysia
          that means i can just flash "f2" file format as "bin" format on the same bios?
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • lanovey
            SF314-41 BIOS without internal display
            by lanovey
            Hello there,
            I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
            I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
            06-13-2025, 02:38 AM
          • iZakre
            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
            by iZakre
            Hello everybody!
            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
            The thing is that I had installed TeamViewer and could log into the computer...
            02-19-2023, 02:27 PM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
