> Possible to repair/replace SMD capacitor in VGA?
  • gerbercage
    • Oct 2018
    • 20
    • Malaysia
    I got VGA card one day when boot, nothing show out.
    Later I found out 1 SMD capacitor spoil as show in photo. (Label C834)
    I check other SMD at near, none of them got any label nor value show out so is that possible for me to repair/replace this with other SMD capacitor that look similar? (same length,same height, something like that)
    Quite waste if 1 card just throw out like that with just 1 SMD down.
    I think C843 and C841 should be exactly same with C834.
    Any opinion/suggestion? Anyway to know the value? or simply get something near to that?
    Here also a link from website that got very detail look on the board. (Can enlarge after you choose the board photo)
    https://www.nix.ru/autocatalog/gigab...=2258&pid=2258
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: > Possible to repair/replace SMD capacitor in VGA?
    Usually failure on GTX460 is due to the GPU. You can try replacing that capacitor but don't get your hopes too high.
    It seems it is a decoupling cap on the PCIe power rail. Try to find a cap with the same size on the board, and then measure it with some calipers, to know the SMD package size (like 0805). Then you can order the highest capacity capacitor rated for 16V or 25V in that package size.
    • gerbercage
      • Oct 2018
      • 20
      • Malaysia
      I measure it. It is 1.24mm x 2.1mm so it is 0408?
      Someone say x7r with 10uf, 0.1uf and 0.01uf.
      I don't know whether is 10uf, 0.1uf or 0.01uf so I go with 10uf right? then with 25V?
      • piernov
        • Jan 2016
        • 4435
        • France
        0805 then, I'd pick a 10uF or 22uF, 25V.
          master hoarder
          • May 2008
          • 12170
          • Bulgaria
          +1
          If you had the video card working in your computer and you never touched it before it went bad, chances are indeed it's the GPU chip that has failed and most likely that cap was gone/missing from before.
          On slightly older video cards, I find that particular cap to be usually in the range of 1 to 4.7 uF. But 10 uF? -very unlikely. Either way, the exact capacitance isn't too important. 1 to 4.7 uF @ 16V or 25V will work fine.
          But like Piernov said, that very likely will NOT fix your video card.
          One thing you can attempt, if the above doesn't fix your card, is to reflow it... though that will be only a temporary repair, at best (if it even works). Bottom line is there's no permanent fix for a bad GPU chip.
          • gerbercage
            • Oct 2018
            • 20
            • Malaysia
            Originally posted by momaka
            +1
            Thanks to both of you. I will try to get that first. For reflow, I think I have to check from website first because I not very know about it and don't know whether I got tools to do it or not.
            • piernov
              • Jan 2016
              • 4435
              • France
              Well… the ghetto way to do it is 8min at 200°C in the oven covered with aluminum foil, only a window around the GPU chip and under it. Better not do it if it's not necessary though.
              • Detro
                • Dec 2018
                • Polska
                Hi, I'm having a similiar issue, how is your card doing? Did you replace that cap?
                  master hoarder
                  • May 2008
                  • 12170
                  • Bulgaria
                  It's not the cap that's the issue. It's simply the GPU chip going bad.
                  • chth96
                    Is it no harm to replace with capacitor without ripple current rating?
                    by chth96
                    When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                    Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                    But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                    Rubycon YK DataSheet (b...
                    04-19-2024, 05:19 AM
                  • chth96
                    If I replace with inferior capacitor, Is it No harm to other IC components at all?
                    by chth96
                    I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                    Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                    It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                    So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                    I know that these capacitor will not last as long as nichicon capacitor...
                    12-22-2023, 04:34 AM
                  • chth96
                    Should I replace polymer capacitor?
                    by chth96
                    a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                    I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                    Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                    Is this ESR value of polymer capacitor correct?...
                    11-18-2022, 04:22 AM
                  • cap__
                    Can I replace 15uf capacitor with 22uf?
                    by cap__
                    "If I wanted to replace an old 15uF/400V capacitor with a new one,
                    I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
                    11-29-2023, 11:16 AM
                  • Prolog
                    RTX 3080 FE Identifying capacitor
                    by Prolog
                    Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                    I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                    I hope these photos make it clear which component I am referring to:
                    (yes, the soldering is a bit botched from removing the blown one, I know)
                    I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                    12-01-2024, 08:27 PM
