to recap or not to recap that is the question.
  • argon99
    • May 2009
    • 5
    Hello all
    I have a EVGA 7600 GS that has blown caps just like this one:7600 gt blown caps
    I called EVGA and they were nice enough to offer me another graphics card without warranty. My problem is they didn't say what kind of card they would send. It could be one of the same or greater value ( I spent $120 for this card) Or they could send me a forty dollar card. I just don't know what they are going to do. Now I could replace the caps in the video card and have a good card, if nothing else went when the caps went. And by the way four of the five 1500 uf 6.3v caps blew. SO maybe other parts went with them.
    The big question is do I trust EVGA to send me a comparable value card or should I try and fix the card myself?
    I'm glad I found this site. I have a number of MB that are real flaky and are just gathering dust. I think I will replace the caps and see what happens. Maybe I can bring them back from the dead.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: to recap or not to recap that is the question.
    EVGA is a very good company
    Just ask them what they will send you?
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      EVGA is a very good company. See what they send you for a graphics card. Are they going to make you send yours back in order to get the new one? If not, let them send you the comparable one and if your recap the 7600gs, well now you have 2 good graphics cards.
      • argon99
        • May 2009
        • 5
        They want me to send back the card with the blown caps. From both of you saying that EVGA is a good company I will send the card back and just ask them if they would ship it back to me with the new card so I can "practice" resoldering caps. They just might do it. The card is worth nothing to them. And the person I talked to did seem to be working for a good company. I didn't get any BS from them. And I told the guy he should come to this site and check out how many products have bad caps. He did call it a "conspiracy theory" that MBs and graphic cards have bad caps. I think he just didn't know. He did sound rather young.
        • FZG
          EVGA Nu Audio Sound Card - Not Working
          by FZG
          I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
          The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
          I found...
          03-07-2025, 11:44 AM
        • Christos Tsiligiannis
          Marian Trace Alpha sound card repair help
          by Christos Tsiligiannis
          Hello to the forum.
          My name is Christos, I am new to the forum here and i am posting from Greece.
          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
          So i tried asking for a schematic from the company and they would not give me one. Instead they...
          11-18-2024, 05:26 AM
        • Kemer
          Graphics Card mounting frame
          by Kemer
          Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
          As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
          I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
          What worries me right now is the possibility that...
          09-14-2024, 08:57 AM
          HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
          This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
          09-06-2024, 08:30 AM
        • benwaterson
          Gigabyte Aorus 1080ti - card not initialising
          by benwaterson
          Hi there.
          Have searched various forums but haven't come across the exact issue I am having.
          Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
          I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
          Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
          02-05-2022, 11:42 AM
