Two motherboards, need help to fix them.
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    • Romania
    Re: Two motherboards, need help to fix them.
    Originally posted by Sparkey55
    Are these ohm readings taken from the switches alone or from the motherboard pin headers? Normally OPEN switches should read as zero ohms when closed (pushed in) and infinite when open (not pushed in).
    MB pin headers, since I am breadboarding the board.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
    • Sparkey55
      • Jan 2010
      • 1523
      have you tried disconnecting the RESET switch from the motherboard and use it in place of the PWR switch?
        • 31248
        i test boards by just shoving my screwdriver between the pins - ghetto!
        • Sparkey55
          • Jan 2010
          • 1523
          I would normally suggest that approach but I am trying to determine it the problem is with the motherboard or externally. Hence trying to rule out the switches as a problem since those items are common failure points.
          • Dan81
            SNES-powered
            • Oct 2013
            • 1866
            • Romania
            Erm...
            The measurements were done on the pin headers. So using the reset switch in place of PWR would do the same.
            stj - Had it been that easy, the problem would be fixed by now
            Main rig:
            Gigabyte B75M-D3H
            16GB DDR3-1600
            Delux MG760 case
            • Sparkey55
              • Jan 2010
              • 1523
              Erm...
              Switches can and do go bad from time to time. Since you did not say that you tested the switches that is the most logical test to perform in order to rule out external connector issues. Using the RESET switch for a PWR switch will rule out a bad switch for PWR ON and OFF and just the opposite if the RESET switch was bad. Since you are not doing a follow up on our suggestions we have no way to know if those suggestions are working or not. That makes it difficult to troubleshoot the problem. What exactly did you short on the motherboard? The more information that you give the better we can help you.
              • Sparkey55
                • Jan 2010
                • 1523
                Have you checked the BIOS setting for the PWR ON switch behavior? Chose the option for instant power off or holding the switch in for greater than 4 seconds? Your symptoms suggest a problem with the Southbridge chip. A corrupt BIOS is also possible.
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1866
                  • Romania
                  #28
                  There's none for any switch, and I just checked all settings in the BIOS again this morning.
                  SB isn't bad or else it would get burning hot to the touch.
                  BIOS was updated today, and I get the same behaviour.
                  I am not using any switches on the main panel, hence why I didn't bother with measuring them, as I never used this board in a case.
                  As for what I am shorting, it's the two power switch pins (pins 7 and 8 marked in black) on the JFP1 header (JFP2 is for the case speaker and power LED).
                  Main rig:
                  Gigabyte B75M-D3H
                  16GB DDR3-1600
                  Delux MG760 case
                  • Sparkey55
                    • Jan 2010
                    • 1523
                    Power Management Setup>Power Button Function
                    Southbridge and/or the associated parts can be bad without getting hot.
                    According to the manual The power switch should be connected to pins 6 and 8 not pins 7 and 8.
                    The reset switch should connect to pins 5 and 7.
                    • Dan81
                      SNES-powered
                      • Oct 2013
                      • 1866
                      • Romania
                      #30
                      I accidentally shorted the 5v rail to the green wire once (it didn't respond to the power switch once and I figured out shorting the green to black on the ATX header would fix that - bad idea. No, it wasn't the 5vSB rail that was bad back then as all PSUs I have are recapped) and since then this happens. It's not 5vSB (I think that's what the SB runs from? Saying this because most burnt SB are caused by bad 5vSB) that is the culprit, so the Southbridge is STILL alive. Also, MB was seldom used by its original owner, because he complaint it was finnicky with RAM. (more like his RAM sticks were cheap crap, as both a A-DATA stick and a Corsair XMS POST'd successfully)
                      Power Button function is set to Power Off, and I figured out I mismatched the pins in my previous post - it's 6 and 8, as you said. Nevertheless I still have the problem (and yes, I am shorting the right pins ever since the beginning of this thread, even if I mismatched the numbering of the pins in my post.
                      This is a hardware problem unrelated to the physical power switches OR the BIOS or the southbridge. I think I should make a video for you all to see what is the exact problem.
                      As for the second board, it's already trashed - that one actually HAS a bad SB, even if it turned on for 3 seconds. (and the 5v rail on it might be shorted as I measured about 28ohms on it, way too much than on 12 and 3.3v)
                      Main rig:
                      Gigabyte B75M-D3H
                      16GB DDR3-1600
                      Delux MG760 case
                        • 31248
                        trace the switch line of the atx socket back to it's source incase there is a shorted transistor or fet on it.
                        • madscientist750
                          Replacing electrolytic caps by solid caps on old motherboards
                          by madscientist750
                          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                          10-19-2025, 06:10 AM
                        • qwerty99
                          Xbox 1.6 Motherboards and Polymer Capacitors
                          by qwerty99
                          Hello!
                          I need to change the capacitors on my three original Xboxes.
                          Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
                          The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
                          The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
                          I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
                          06-26-2022, 12:53 AM
                        • Foetuss
                          Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                          by Foetuss
                          Hi all
                          Hope this is in the correct place.
                          I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                          Could use some double checking to see if I'm not doing something stupid .
                          Pictures of the boards are attached.
                          What I will be replacing with what : (planned)
                          Soltek Golden ::
                          4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                          6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                          01-18-2025, 11:44 AM
                        • madscientist750
                          Looking for capacitor lists for Motherboards, Video Cards, Home Appliances
                          by madscientist750
                          I would like to ask if there is some kind of capacitor lists for motherboards, power supplies, video cards, audio cards, microcontroller powered home appliances, and so, that i could try to find and download. I use to repair those things and i would find it helpful if i could know in advance what parts may i need for common repairs.
                          07-09-2024, 09:24 AM
                        • blues_spirit
                          practical courses for troubleshooting pc motherboards
                          by blues_spirit
                          Hello from France,
                          mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                          Do you think this is feasible for me? I...
                          12-18-2022, 12:56 PM
