Some goodies I will be working on
  • Solder Boy
    • Nov 2006
    • 178
    Thought I would take some before photos of a few of the motherboards I will be attempting to repair. I recycle electronics for a living and there is never a shortage of motherboards with bad caps!
    Haven't fired any of these up yet so I don't know how successful I will be:
    Anyhooo here are the pics:
    www.bcrelectronics.ca
  • Wizard
    • Mar 2008
    • 2296
    Re: Some goodies I will be working on
    Toss the VIA chipset board or add more MLCC capacitors to all the chips and clock chips, what I mean on the supply rails for them, keep the intel chipsets. SiS maybe if drivers works 100%. The last two pictures is clones of clones. Blech.
    The second picture from top is GOOD one to work on and what this came from?
    Oh, you are in Ontario!
    Cheers, Wizard
    • sofTest
      • Aug 2008
      • 361
      From the layout I can see in the picture, it looks like the NetVista A30 or NetVista 8300 series I've got, except my 8300 got Rubycon MBZ's and A30 got Sanyo WG's, all fine, instead of those bulging GCS'. Mine are 1.2 and 1.5 revision boards, so IBM probably later on found out that GSC was not a supplier for the future. On an older NetVista 6300-series I've got (different layout and SDRAM), there are 16 bulging GCS'.
      Be a mensch
      • Solder Boy
        • Nov 2006
        • 178
        Well to be honest haven't had that much problems with VIA boards same with Intel boards, I find with Intel they are built like a brick, short of shorting it out can't kill them babies.
        The last two boards I wanna do just for the hell of it and see what happens.
        • Wizard
          • Mar 2008
          • 2296
          Okay, fair enough!
          Cheers, Wizard
          • MMH3
            Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
            by MMH3
            i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
            Never ever i experienced problems with that.
            Now i have one 5050sff machine, where this jumper isnt working at all.
            I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
            The history of the machine is that i used it in my office...
            03-23-2025, 09:28 PM
          • DynaxSC
            GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
            by DynaxSC
            I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
            There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
            The board is generally working now, all PCIe ports are working, Windows installs normally.
            However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
            The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
            03-10-2025, 12:27 PM
          • obelix24
            Macbook Air 2020 (a2179) - touch id not working
            by obelix24
            Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
            I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
            02-09-2025, 12:57 PM
          • hopkok
            Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
            by hopkok
            Hi masters, I need your help.
            I am working on Lenovo Legion 16ITHg6
            Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
            INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
            My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
            AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
            Power LED is not working as well, power button working well.
            UI26 ??? is there any firmware too? Powered by +3VALW_AG.
            Motherboard...
            05-04-2025, 09:35 AM
          • bociub
            laptop freezes, usb 2.0 not working, usb 3.0 working
            by bociub
            Hi there,
            It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
            Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
            08-25-2024, 03:44 PM
