AOpen AX4BS Pro with bad Lelon caps
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Nicely built P4 board which uses SDRAM - worth preserving
    Spoiled by Lelon RXA caps - 2 of 2200uf 16v and 1 of 1500uf 6.3v
    Other caps are Panasonic FJ 2200uf 6.3v and Chemicon (?) TMZ 1000uf 6.3v
    Talk about spoiling a nice board by scrimping a few cents
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: AOpen AX4BS Pro with bad Lelon caps
    Lelon replaced by same spec Sanyo (tested on ESR meter) from donor boards - all working well
    One of the big Lelon propped upside down in the pic to show its split bung
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      I got sent here from your GA-8I915P Duo motherboard thread.
      Yes, epic thread revival, I know.
      Anyways, this seems like a decent old board. Are those Sanyo caps next to the 4-pic CPU connector legit, though? Their vent suggests fake Sanyo. Also, there is a free spot next to them. Should have inserted another cap there for extra filtering.
      • Wester547
        • Nov 2011
        • 1269
        • USA.
        ^ 12.5mm and larger diameter Sanyo (Suncon) capacitors have always used the overlapping X in lieu of the typical K vent stamp. Now, if it was a regular + vent stamp, they'd be fake. The replacements look to be the WX series, which is certainly worlds better than the very horrible Lelon RXA series.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Got it. Thanks for the info, Wester.
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3266
            • Singapore
            that manufacturer seems to have absolutely no clue where exactly the right places are to scrimp on caps...
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
