GIGABATE R9 290OC no signs of life
  • myth77
    • Feb 2017
    • 380
    • Croatia
    I received this video card, without vents, only board and metal heating sink. I was told that it was used for minning btc.... When plugged in to the computer no signs of life, motherboard/windoes doesnt recognise it...no lights, just a heating gpu (not too hot)....
    First i try to reprogram bios from some dump i found on the internet but no luck. This card has two bios chip, and you can swich it, so i reprogrammed both.
    Later i did i multimeter testing and i found that one of the bios chip pm25ld010 is dead, shorting pin gnd to pin vcc. When i remove it no continuity between vcc and ground. tested the chip removed from the board, it is showing short pin 4 to pin 8. Other chip is ok. But i do have continuity between vcc and hold on the board now, while chips removed, pins 8 and 7. I dont know is this normal because i dont have a boardview for this card...or there is short somewhere else? Does anyone have boardview? or the same card so he can test it with multimeter?
    thank you!
  • KYBOSH
    Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
    by KYBOSH
    I picked this one up today.
    Previous owner says no signs of life.
    TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
    Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
    The TV model is QN65LS03BAFXZA - version: CB06
    The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
    I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
    Will keep you all...
    04-05-2025, 08:32 PM
  • someonenotyou
    Dell Vostro 3501 - no signs of life after BIOS read
    by someonenotyou
    Hi.
    I have a laptop Dell Vostro 3501 which did not POST. When connected to power supply and turn it on, the keyboard backlight would turn on but nothing else. Sometimes there was 1 BEEP code indicating problems with BIOS.
    Then I disassembled it to read the BIOS chips. It had 2 - 64mbit and 128mbit. I connected CH341A (with 3.3v mod) to both of the chips (still soldered on main board) and read them.
    After I reassembled laptop back and tried to turn it on. Now there is no sign of life. Not even keyboard backlight.
    Then I took the motherboard out...
    01-27-2025, 05:15 AM
  • tranquility
    HP EliteBook 850 G5 without signs of life
    by tranquility
    hello, i have a problem with HP EliteBook 850 G5
    shoring no signs of life. led near charging port and on/off button are off.
    board it taking just a few mA..i think it was 10mA
    i measured some things but i don´t find anything
    the ACOK ? pin 24 FRWPG (pin 24) am ISL9538h is low with 0V
    but i dont know why
    i cant really understand what the mosfets in the pictures are doing for crazy things.
    i measuered voltage on coils....but now on mosfets near the coils too and they all had more than 10v i think one was there with 8v or something....so...
    12-02-2024, 05:57 AM
  • ongobongo
    Asus Rog Strix starts but no screen or other signs of life
    by ongobongo
    Hi Guys,
    I'm trying to repair this Asus ROG Strix notebook for a longer while now.
    Mainboard is G531GW rev. r1.6
    When attaching power notebook straight up turns on but no picture or similar signs of life. Voltages are all there (VCCCORE, VCCSA, NVVDD, 1.05V, 1.2V, 5V, 3V, 12V …. Only VCCGT is missing, but that is ok as far as I read), no obvious shorts on any rails. CPU gets hot quickly without heatsink, GPU gets moderately warm and PCH gets warm as well. EC should be good: power button responds to a long press and after a while the CPU fan kicks in.
    What I have found out...
    08-06-2024, 01:13 PM
  • feliks912
    ThinkPad T490 20N2000CSC NM-B901 no signs of life - short on 5V SMPS, ThinkEngine-3 hot - *speculations*
    by feliks912
    Attached schematic 🙂.
    Laptop gives no signs of life. No fan and no CPU heat.
    Think Engine BD4179MWV is hot on plugging in *AND* pressing the power button.
    Discovered short to ground on VCC5M power delivery IC NB690GRP (5 volt line, not the high current VCC5M_PD) which is one of the ways that chip is powered. I'm puzzled.
    Nothing else is warm on the board. CPU resistances are OK, 9V VSYS line is present from the BMIC. All misc and cables are disconnected.
    What do you guys think happened? I've got two theories:
    If the...
    I think ThinkEngine shorted first
    50.00%
    1
    I think 5V SMIC shorted first
    0%
    0
    I think something else happened
    50.00%
    1
    05-07-2024, 04:44 PM
