Old shuttle recapped and running strong
  • Preowner
    • Mar 2005
    • 13
    Got my cap kit in a few days ago for my fv25 board. Sofar I ran it for 8hrs next to me at work. Only instability I found was when I was 5min into running some 3d demos to see what the onboard vid could do (of course, not much). That was most likely because of heat though:
    I hadto replace some of the stock fans, so I undervolted them to save my ears. It got spicy enough in there that psu and cpu hsf were almost burning to the touch, and hdd and optical were way too hot for comfort. I was forced to put the cpu fan and rear 60mm fan(the only case fan) back to 12v.
    As far as recapping goes. I have only replaced the 3 big 3900uf caps that were bulging and venting. This is mostly because I thrashed that board while trying to remove those 3. I had to heat the solder pads so so many times to remove the caps and clear of solder. At one point I was balancing the board on its side with the iron in one hand and the sucker in the other. Needless to say I heeded almost none of the advice on this site/forum but I got the job done, and it seems to be doing pretty well under some intense heat loads.
    Lets see If I can scrounge up some pics for fun.
  • Preowner
    • Mar 2005
    • 13
    BTW I used some 62/36/2 .020" solder and it worked great. Flowed so nicely even with my never-cleaned tip. Silver electronics solder kicks ass.
    I got it at Jameco
    • Deric
      • Mar 2005
      • 5
      good results
      One thing I have used since my school days is a vise to hold the electronics board while I solder. Oh and BTW I just recapped a SV25 and so far 3-4 weeks with no issues. I originally noticed the bulging on the 3 same caps you mentioned (by the CPU) I did a Google on SV25 capacitors and found this site. I had to go with the 6.3v version as the 10v is difficult to locate. Oh and on the Silver bearing solder, I've used the same stuff for over 9 years and have had nothing but good luck with it.
      -Deric
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        -Deric
        The (3) caps only have VCORE present at their positions, never exceeding 2 volts. 10v caps is overkill, and un-necessary. The 'Gloria' caps they used were likely the cheapest they could find, and just happened to be 10v caps. I've recapped a LOT of these, using 4700uF 6.3v caps, and well over a year later, still running flawlessly. The substitution was made after a lot of testing and homework.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • yanz
          • Nov 2004
          • 910
          what if i recap these with 2200uF 6.3V caps? I've found panasonic 3300uF (FC)caps but the leads are too big for the hole.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            get regular radial in the fc.
            maybe you were sold snap in type?
            go up in capacitance if you cant get the original value.more is better up to a point.those 3 caps filter cpu vcore.
            • yanz
              • Nov 2004
              • 910
              ya, that 3300uf one is 16v, and i can't find those 10v or below. it's super big (12mm diameter?)
              "snap in type" ? is that the model with very short leads (1+ cm)? yes i have those. the other model i can find of FC series (panasonic) is 1000uF 10V.
              well, i have another mobo (shuttle mv19) with bloated caps. the value are 2700uF. so would it be okay if i recap those with the 3300 uF caps? i'll try to find the 10v model (can only get rubycon 85c "YK" and some "made in japan" brown 105C caps -- but they aren't nichicon)...
              • yanz
                • Nov 2004
                • 910
                i was wrong. that 3300uf ones are 10v, and they are 12mm diameter.
                • AK0R
                  • Mar 2005
                  • 204
                  Here is a link to another site that sells replacement capacitors (I received Rubycons) that has 3300uF, 6.3V, 10mm caps available:
                  http://www.computekinc.us/prod01.htm
                  • yanz
                    • Nov 2004
                    • 910
                    thanks, but i live in indonesia..
                    all rubycons i can get here is "YK" series (85C)
                    also if anybody know is this cap good? -> [M]CEHFQ Japan 105C (1500uF 16V) with darkblue color and silver strip.
                    • corrize
                      Best way to solder LVDS connector for beginner (and qfn) ?
                      by corrize
                      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                      See the test :
                      https://youtu.be/bNAzC-EvqHs?t=1767
                      With hot air from bellow the board, that's...
                      03-09-2023, 02:57 AM
                      SHUTTLE XS 3600BA D2700 Specification for Upgrade or Repair
                      This specification for the SHUTTLE XS 3600BA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XS 3600BA boardview and XS 3600BA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE XS 3600BA...
                      09-12-2024, 03:44 PM
                      SHUTTLE XPC nano NC1010XA XPC nano 4205U Specification for Upgrade or Repair
                      This specification for the SHUTTLE XPC nano NC1010XA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC1010XA boardview and XPC nano NC1010XA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-12-2024, 03:36 PM
                      SHUTTLE XPC nano NC1010BA XPC nano 4205U Specification for Upgrade or Repair
                      This specification for the SHUTTLE XPC nano NC1010BA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC1010BA boardview and XPC nano NC1010BA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      SHUTTLE XPC nano NC3000BA XPC nano 3865U Specification for Upgrade or Repair
                      This specification for the SHUTTLE XPC nano NC3000BA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC3000BA boardview and XPC nano NC3000BA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
